PETSC debugger
Ryan Yan
vyan2000 at gmail.com
Mon Jul 20 12:04:37 CDT 2009
Thank you very much, Jed.
I will try your suggestion.
Yan
On Mon, Jul 20, 2009 at 5:47 AM, Jed Brown <jed at 59a2.org> wrote:
> Ryan Yan wrote:
> > Only debugging one processes is a way to go for my current bug(s).
> There is another option for debugging multiple processes using screen
> instead of X. For the sake of cleanliness, start a new terminal and
> open a special screen session for debugging
> $ screen -S sdebug
> Now in your original terminal, run the program like
> $ mpirun -n 4 ./myapp -start_in_debugger -debug_terminal "screen -S sdebug
> -X screen"
> (the quotes are important)
> This opens four new windows within the screen session named "sdebug".
> Recent versions of MPICH2 have a -gdb option which is a lightweight skin
> for gdb that sends commands to all processes and collates the results,
> but also allows you to drop to per-process debugging. I had trouble
> with it prior to release 1.1.
> Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090720/37a4d93d/attachment.htm>
