PETSC debugger
Barry Smith
bsmith at mcs.anl.gov
Sat Jul 18 23:54:18 CDT 2009
Are you sure the other window isn't lurking away somewhere off (or
nearly) off the screen?
Maybe try shutting down the x server and restarting?
Barry
On Jul 18, 2009, at 11:50 PM, Ryan Yan wrote:
> Thank you very much, Barry.
> After I use the vyan2000-linux:0.0, I got errors without any gdb
> window.
> vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/
> examples/tutorials/ttt2$ mpirun -np 2 ./rpisolve -
> ksp_monitor_true_residual -start_in_debugger -display vyan2000-linux:
> 0.0
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26518 on
> display vyan2000-linux:0.0 on machine vyan2000-linux
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26519 on
> xterm Xt error: Can't open display: vyan2000-linux:0.0
> Then
> I changed back,
> ksp_monitor_true_residual -start_in_debugger -display :0.0
> Same as before, error messages with only a single gdb window, (and
> the window shows up at different place at different instances).
> Yan
> On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> Try using -display vyan2000-linux:0.0
> Shouldn't make any difference but since it appears you are running
> everything on the same machine what you have given should work.
> Barry
> On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
> Hi All,
> I am tring to use the PETSc runtime option -start_in_debugger.
> However, when I attach the debugger at run time to each process,
> there are error messages and I only get one gdb window(Am I suppose
> to get as many as the number of the processes?)
> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307 on
> display :0.0 on machine vyan2000-linux
> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306 on
> Then, only a *single* gdb window prompts out. When I run with 3
> process, there are only *two* gdb windows.
> Thank you very much in advance,
> Yan
