PETSC debugger
    Ryan Yan
    vyan2000 at gmail.com
    Sat Jul 18 23:50:55 CDT 2009
Thank you very much, Barry.
After I use the vyan2000-linux:0.0, I got errors without any gdb window.
vyan2000 at vyan2000-linux:~/local/PPETSc/petsc-2.3.3-p15/src/ksp/ksp/examples/tutorials/ttt2$
mpirun -np 2 ./rpisolve -ksp_monitor_true_residual -start_in_debugger
-display vyan2000-linux:0.0
[0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26518 on display
vyan2000-linux:0.0 on machine vyan2000-linux
[1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26519 on display
xterm Xt error: Can't open display: vyan2000-linux:0.0
Then
I changed back,
-display :0.0
Same as before, error messages with only a single gdb window, (and the
window shows up at different place at different instances).
Yan
On Sun, Jul 19, 2009 at 12:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Try using -display vyan2000-linux:0.0
>  Shouldn't make any difference but since it appears you are running
> everything on the same machine what you have given should work.
>   Barry
> On Jul 18, 2009, at 11:24 PM, Ryan Yan wrote:
>  Hi All,
>> I am tring to use the PETSc runtime option -start_in_debugger.
>> However, when I attach the debugger at run time to each process, there are
>> error messages and I only get one gdb window(Am I suppose to get as many as
>> the number of the processes?)
>> -display :0.0
>> [1]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26307 on display
>> [0]PETSC ERROR: PETSC: Attaching gdb to ./rpisolve of pid 26306 on display
>> Then, only a *single* gdb window prompts out. When I run with 3 process,
>> there are only *two* gdb windows.
>> Thank you very much in advance,
>> Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090719/238e3e8e/attachment.htm>
