ifort -i8 -r8 options
Barry Smith
bsmith at mcs.anl.gov
Tue Jul 14 11:42:07 CDT 2009
On Jul 14, 2009, at 11:18 AM, Andreas Grassl wrote:
> Barry Smith schrieb:
>> Mumps and hypre do not currently support using 32 bit integer
>> indices,
> here you mean 64?!
>> though the MUMPS folks say they plan to support it eventually.
>> Changing PETSc to convert all 64 bit integers to 32 bit before
>> passing
>> to MUMPS and hypre is a huge project and we will not be doing that.
>> You need to lobby the MUMPS and hypre to properly support 64 bit
>> integers if you want to use them in that mode.
>> Unless you are solving very large problems it seems you should be
>> able
>> to use the -r8 flag but not the -i8 flag.
> For my needs, this is certainly true, but I don't have the whole
> sourcecode and
> I am not able to get a working Diana-program if I omit the -i8 flag.
> so you suggest casting the input data from Diana to PetscInt which
> is defined
> 32-bit?!
If you can do that. But it means copying any integer arrays from
64 bit integer arrays to
32 bit integer arrays.
Barry
> Cheers,
> ando
> /"\ Grassl Andreas
> \ / ASCII Ribbon Campaign Uni Innsbruck Institut f. Mathematik
> X against HTML email Technikerstr. 13 Zi 709
> / \ +43 (0)512 507 6091
