A question about parallel computation
Thu Jul 9 06:20:13 CDT 2009
I think it is time to ask your system administrator for help.
  Matt
On Thu, Jul 9, 2009 at 12:02 AM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
> Firstly, thanks for all your replies!
> I changed compiler to MPICH and tried a sample successfully but the
> problem is still there.
> I ran my code in 4 nodes and each node have 8 processors. And the
> information I saw is like:
>  NODE        LOAD
>       0             32
>       1              0
>        2             0
>       3              0
> Normally, in that case, we should see is:
> NODE        LOAD
>       0             8
>       1              8
>        2             8
>       3              8
> So, anyone got any idea about this?
> Thank you in advance!
> Sincerely,
> YIN
> On Wed, Jul 8, 2009 at 4:15 PM, Xin Qian<chianshin at gmail.com> wrote:
> > You can try to run sole MPI samples coming with OpenMPI first, make sure
> the
> > OpenMPI is running all right.
> > Thanks,
> > Xin Qian
> > On Wed, Jul 8, 2009 at 4:48 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
> >> I tried OpenMPI build PETSc and used mpirun provided by OpenMPI.
> >> But, when I check the load on each node, I found the master node take
> >> all the load
> >> and others are just free.
> >> Did you have any idea about this situation?
> >> Thanks in adcance!
> >> Sincerely,
> >> YIN
> >> On Wed, Jul 8, 2009 at 1:26 PM, Satish Balay<balay at mcs.anl.gov> wrote:
> >> > Perhaps you are using the wrong mpiexec or mpirun. You'll have to use
> >> > the correspond mpiexec from MPI you've used to build PETSc.
> >> > Or if the MPI has special instruction on usage - you should follow
> >> > that [for ex: some clusters require extra options to mpiexec ]
> >> > Satish
> >> > On Wed, 8 Jul 2009, Yin Feng wrote:
> >> >> I am a beginner of PETSc.
> >> >> I tried the PETSC example 5(ex5) with 4 nodes,
> >> >> However, it seems every nodes doing the exactly the same things and
> >> >> output the same results again and again. is this the problem of petsc
> >> >> or
> >> >> MPI installation?
> >> >> Thank you in adcance!
> >> >> Sincerely,
> >> >> YIN
> > QIAN, Xin (http://pubpages.unh.edu/~xqian/<http://pubpages.unh.edu/%7Exqian/>
> > xqian at unh.edu chianshin at gmail.com
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090709/eb7961c8/attachment.htm>
