A question about parallel computation
Xin Qian
chianshin at gmail.com
Wed Jul 8 16:15:18 CDT 2009
You can try to run sole MPI samples coming with OpenMPI first, make sure the
OpenMPI is running all right.
Xin Qian
On Wed, Jul 8, 2009 at 4:48 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
> I tried OpenMPI build PETSc and used mpirun provided by OpenMPI.
> But, when I check the load on each node, I found the master node take
> all the load
> and others are just free.
> Did you have any idea about this situation?
> Thanks in adcance!
> Sincerely,
> YIN
> On Wed, Jul 8, 2009 at 1:26 PM, Satish Balay<balay at mcs.anl.gov> wrote:
> > Perhaps you are using the wrong mpiexec or mpirun. You'll have to use
> > the correspond mpiexec from MPI you've used to build PETSc.
> > Or if the MPI has special instruction on usage - you should follow
> > that [for ex: some clusters require extra options to mpiexec ]
> > Satish
> > On Wed, 8 Jul 2009, Yin Feng wrote:
> >> I am a beginner of PETSc.
> >> I tried the PETSC example 5(ex5) with 4 nodes,
> >> However, it seems every nodes doing the exactly the same things and
> >> output the same results again and again. is this the problem of petsc or
> >> MPI installation?
> >> Thank you in adcance!
> >> Sincerely,
> >> YIN
QIAN, Xin (http://pubpages.unh.edu/~xqian/)
xqian at unh.edu chianshin at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090708/60940bb1/attachment.htm>
