make test
Yixun Liu enjoywm at cs.wm.edu
Sun Jul 5 12:46:51 CDT 2009
After making test, I received a lot of warnings and lib load failures.
Running test examples to verify correct installation
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
DAT: library load failure: /usr/lib64/libdaplcma.so.1: undefined symbol:
dat_registry_add_provider
WARNING: Failed to open "OpenIB-cma"
[DAT_PROVIDER_NOT_FOUND:DAT_NAME_NOT_REGISTERED].
This may be a real error or it may be an invalid entry in the uDAPL
Registry which is contained in the dat.conf file. Contact your local
System Administrator to confirm the availability of the interfaces in
the dat.conf file.
WARNING: Failed to open "OpenIB-cma-1"
the dat.conf file.
DAT: library load failure: /usr/lib64/libdaplscm.so.1: undefined symbol:
WARNING: Failed to open "OpenIB-mthca0-1"
the dat.conf file.
WARNING: Failed to open "OpenIB-mthca0-2"
the dat.conf file.
WARNING: Failed to open "OpenIB-mlx4_0-1"
the dat.conf file.
WARNING: Failed to open "OpenIB-mlx4_0-2"
the dat.conf file.
WARNING: Failed to open "OpenIB-iwarp"
the dat.conf file.
[0,1,0]: uDAPL on host md was unable to find any NICs.
Another transport will be used instead, although this may result in
lower performance.
lid velocity = 0.0016, prandtl # = 1, grashof # = 1
Number of Newton iterations = 2
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
processes
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
[0,1,1]: uDAPL on host md was unable to find any NICs.
lower performance.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
lower performance.
Possible error running Graphics examples
src/snes/examples/tutorials/ex19 1 MPI process
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
lower performance.
Error running Fortran example src/snes/examples/tutorials/ex5f with 1
MPI process
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
the dat.conf file.
lower performance.
Number of Newton iterations =     4
Completed test examples
Thanks.
Yixun
