matrix creation on LAPACK mode
Zi-Hao Wei socrates.wei at gmail.com
Fri Jul 3 02:50:27 CDT 2009
Hi
I remember that when you use LAPACK as eigensolver the SLEPc will
automatically convert sparse matrix into dense matrix by the function
SlepcMatConvertSeqDense.
On Fri, Jul 3, 2009 at 12:30 PM, Takuya Sekikawa<sekikawa at msi.co.jp> wrote:
> Hello
> I made eigenvalue solver program with SLEPc. in my program, to
> setup matrix, I use MatCreateSeqAIJ() function.
> void setupMatrix(int m, int n)
>        PetscErrorCode ierr;
>        ierr=MatCreateSeqAIJ(PETSC_COMM_WORLD, m, n, nz, PETSC_NULL,
> &g_A);
> Normally I select solver as KrylovSchur, but sometimes I switched solver
> to LAPACK. with using LAPACK, result seems to be no problem. but I
> suspect calculation time takes longer (because of using MatCreateSeqAIJ)
> Does switching matrix create function to MatCreateSeqDense() give any
> effect to speed up on LAPACK mode?
> Thanks,
> Takuya
>   Takuya Sekikawa
>         Mathematical Systems, Inc
Zi-Hao Wei
Department of Mathematics
National Central University, Taiwan
Adrienne Gusoff  - "Opportunity knocked. My doorman threw him out." -
http://www.brainyquote.com/quotes/authors/a/adrienne_gusoff.html
