Error Handlers Function
Santolo Felaco
ahuramazda10 at gmail.com
Fri Feb 27 03:55:13 CST 2009
Hi, I have used PetscPushErrorHandler, the handler function is called only
I send CTRL+C signal.
Thanks. Bye.
2009/2/26 Santolo Felaco <ahuramazda10 at gmail.com>
> Ok, Thanks. I will try with Petsc error handler.
> Bye.
> 2009/2/26 Matthew Knepley <knepley at gmail.com>
>> On Thu, Feb 26, 2009 at 1:12 PM, Santolo Felaco <ahuramazda10 at gmail.com>wrote:
>>> Hi, also with return; the handler function isn't called.
>> 1) I missed that you are setting the MPI err handler instead of the PETSc
>> error handler. Sorry.
>> 2) This post belongs on the MPI list. It has nothing to do with PETSc.
>> Matt
>>>> exit(2) does not trigger a PETSc error. SETERRQ does.
>>>> Matt
>>>> On Thu, Feb 26, 2009 at 10:00 AM, Santolo Felaco <
>>>> ahuramazda10 at gmail.com> wrote:
>>>>> Hi,
>>>>> I have setted a handler error function:
>>>>> ierr = MPI_Errhandler_create(errorHandler,&errhandler); CHKERRQ(ierr);
>>>>> ierr = MPI_Errhandler_set(PETSC_COMM_WORLD,errhandler); CHKERRQ(ierr);
>>>>> I have simulated a fault of processor 1:
>>>>> if (rank == 1)) exit(2);
>>>>> MPI_Barrier(PETSC_COMM_WORLD);
>>>>> The process remains blocked and the functions errorHandler is not
>>>>> called.
>>>>> If I use return; instead of exit(2); the process don't remains blocked,
>>>>> I read the error of Petsc but errorHandler is not called.
>>>>> Help me please.
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090227/29a5c259/attachment.htm>
