Error Handlers Function
Santolo Felaco
ahuramazda10 at gmail.com
Thu Feb 26 13:47:16 CST 2009
Ok, Thanks. I will try with Petsc error handler.
Bye.
2009/2/26 Matthew Knepley <knepley at gmail.com>
> On Thu, Feb 26, 2009 at 1:12 PM, Santolo Felaco <ahuramazda10 at gmail.com>wrote:
>> Hi, also with return; the handler function isn't called.
> 1) I missed that you are setting the MPI err handler instead of the PETSc
> error handler. Sorry.
> 2) This post belongs on the MPI list. It has nothing to do with PETSc.
> Matt
>>> exit(2) does not trigger a PETSc error. SETERRQ does.
>>> Matt
>>> On Thu, Feb 26, 2009 at 10:00 AM, Santolo Felaco <ahuramazda10 at gmail.com
>>> > wrote:
>>>> Hi,
>>>> I have setted a handler error function:
>>>> ierr = MPI_Errhandler_create(errorHandler,&errhandler); CHKERRQ(ierr);
>>>> ierr = MPI_Errhandler_set(PETSC_COMM_WORLD,errhandler); CHKERRQ(ierr);
>>>> I have simulated a fault of processor 1:
>>>> if (rank == 1)) exit(2);
>>>> MPI_Barrier(PETSC_COMM_WORLD);
>>>> The process remains blocked and the functions errorHandler is not
>>>> called.
>>>> If I use return; instead of exit(2); the process don't remains blocked,
>>>> I read the error of Petsc but errorHandler is not called.
>>>> Help me please.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090226/964b87dc/attachment.htm>
