petsc-users Digest, Vol 2, Issue 32
STEPHANE TCHOUANMO
tchouanm at msn.com
Tue Feb 24 12:17:27 CST 2009
Here is my -log_summary:
Something looks a bit strange to me; its the MPI Reductions below.
Other than that, i dont see anything relevant.
What do you think?
Thanks
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./diff-conv-opt on a linux-gnu named linux-stchouan with 1 processor, by stephane Tue Feb 24 13:54:35 2009
Using Petsc Release Version 2.3.3, Patch 13, Thu May 15 17:29:26 CDT 2008 HG revision: 4466c6289a0922df26e20626fd4a0b4dd03c8124
Max Max/Min Avg Total
Time (sec): 2.937e+03 1.00000 2.937e+03
Objects: 3.420e+03 1.00000 3.420e+03
Flops: 2.690e+09 1.00000 2.690e+09 2.690e+09
Flops/sec: 9.161e+05 1.00000 9.161e+05 9.161e+05
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 1.189e+05 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 2.9367e+03 100.0% 2.6905e+09 100.0% 0.000e+00 0.0% 0.000e+00 0.0% 1.106e+03 0.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops/sec: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops/sec --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecDot 202 1.0 3.0360e-02 1.0 3.96e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 396
VecMDot 202 1.0 3.0552e-02 1.0 3.94e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 394
VecNorm 1110 1.0 1.2257e+00 1.0 5.40e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 2 0 0 0 0 2 0 0 0 54
VecScale 404 1.0 3.5342e-02 1.0 3.41e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 341
VecCopy 507 1.0 8.4626e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 1408 1.0 1.1664e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 202 1.0 2.6221e-02 1.0 4.59e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 459
VecWAXPY 202 1.0 4.4239e-02 1.0 1.36e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 136
VecMAXPY 404 1.0 7.3515e-02 1.0 3.27e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 327
VecAssemblyBegin 302 1.0 9.2960e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 302 1.0 5.5790e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 603 1.0 1.9933e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 404 1.0 5.5408e-01 1.0 6.52e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 65
MatMult 404 1.0 2.6457e+00 1.0 2.26e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 22 0 0 0 0 22 0 0 0 226
MatSolve 404 1.0 4.6454e+00 1.0 1.28e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 22 0 0 0 0 22 0 0 0 128
MatLUFactorNum 202 1.0 1.5211e+01 1.0 8.85e+07 1.0 0.0e+00 0.0e+00 0.0e+00 1 50 0 0 0 1 50 0 0 0 89
MatILUFactorSym 100 1.0 1.9993e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+02 0 0 0 0 0 0 0 0 0 9 0
MatAssemblyBegin 404 1.0 9.6217e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 404 1.0 1.4601e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 100 1.0 2.4641e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 100 1.0 7.6755e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+02 0 0 0 0 0 0 0 0 0 18 0
MatZeroEntries 99 1.0 3.6160e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SNESSolve 100 1.0 2.9339e+03 1.0 9.17e+05 1.0 0.0e+00 0.0e+00 1.0e+03100100 0 0 1 100100 0 0 91 1
SNESLineSearch 202 1.0 7.9707e+02 1.0 4.35e+05 1.0 0.0e+00 0.0e+00 4.0e+02 27 13 0 0 0 27 13 0 0 37 0
SNESFunctionEval 302 1.0 1.1836e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+02 40 0 0 0 0 40 0 0 0 27 0
SNESJacobianEval 202 1.0 1.7238e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+02 59 0 0 0 0 59 0 0 0 18 0
KSPGMRESOrthog 202 1.0 7.0303e-02 1.0 3.42e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 342
KSPSetup 202 1.0 4.6391e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 202 1.0 2.4101e+01 1.0 9.65e+07 1.0 0.0e+00 0.0e+00 3.0e+02 1 86 0 0 0 1 86 0 0 27 97
PCSetUp 202 1.0 1.7296e+01 1.0 7.78e+07 1.0 0.0e+00 0.0e+00 3.0e+02 1 50 0 0 0 1 50 0 0 27 78
PCApply 404 1.0 4.6487e+00 1.0 1.28e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 22 0 0 0 0 22 0 0 0 128
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Index Set 904 901 107564984 0
Vec 1511 1497 357441684 0
Vec Scatter 604 604 0 0
Matrix 101 99 942432084 0
SNES 100 99 12276 0
Krylov Solver 100 99 1671120 0
Preconditioner 100 99 14256 0
Average time to get PetscTime(): 1.49164e-06
OptionTable: -snes_converged_reason
OptionTable: -snes_max_it 20
OptionTable: -snes_rtol 0.0000001
OptionTable: -snes_stol 0.001
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4 sizeof(PetscScalar) 8
Configure run at: Mon Feb 23 23:01:43 2009
Configure options: --with-debugging=no -with-shared --download-mpich=1
> Message: 7
> Date: Tue, 24 Feb 2009 18:05:38 +0100
> From: STEPHANE TCHOUANMO <tchouanm at msn.com>
> Subject: Petsc slowness on a single processor machine?
> To: <petsc-users at mcs.anl.gov>
> Message-ID: <BAY107-W5D076FE1F3A7037240F88C2AF0 at phx.gbl>
> Content-Type: text/plain; charset="windows-1256"
> Dear all,
> I use petsc to solve a nonlinear convection-diffusion type equation in porous media.
> The built linear system's size is 30000 and its resolution lasts about a hour on a single processor machine (my laptop...).
> I
> run for that a hundred time steps and have in average 4 Newton
> iterations per time step. So a hour seems huge to me with the optimized
> version of Petsc.
> I tryed to profile my code with the options
> "-log_summary" and "-info". What i get out of it is that the first time
> step lasts about 15min representing 25% of the total time and i think
> its not normal.
> The thing is, these 15min happen at the second call
> of the petsc routine "VecScatterCreate()" right after the first Newton residual.
> Any idea?
> Thanks.
> Stephane
> _________________________________________________________________
> Show them the way! Add maps and directions to your party invites.
> http://www.microsoft.com/windows/windowslive/products/events.aspx
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090224/c695a2bf/attachment-0001.htm>
> Message: 8
> Date: Tue, 24 Feb 2009 11:22:18 -0600
> From: Matthew Knepley <knepley at gmail.com>
> Subject: Re: Petsc slowness on a single processor machine?
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> <a9f269830902240922y6751b40aqf8ea84257c139fd9 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> 2009/2/24 STEPHANE TCHOUANMO <tchouanm at msn.com>
> > Dear all,
> > porous media.
> > I run for that a hundred time steps and have in average 4 Newton iterations
> > per time step. So a hour seems huge to me with the optimized version of
> > Petsc.
> > I tryed to profile my code with the options "-log_summary" and "-info".
> > What i get out of it is that the first time step lasts about 15min
> > representing 25% of the total time and i think its not normal.
> > The thing is, these 15min happen at the second call of the petsc routine
> We can't say anything without seeing the entire output of -log_summary.
> Matt
> > Any idea?
> > Thanks.
> > Stephane
> > <http://www.live.com/getstarted.aspx>
> > <http://www.microsoft.com/windows/windowslive/default.aspx>
> > See all the ways you can stay connected to friends and family<http://www.microsoft.com/windows/windowslive/default.aspx>
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
> URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090224/cd1ffccb/attachment-0001.htm>
> petsc-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> End of petsc-users Digest, Vol 2, Issue 32
News, entertainment and everything you care about at Live.com. Get it now!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090224/f3c06de3/attachment.htm>
