partitioning
Sat Feb 21 10:09:18 CST 2009
    PETSc currently only provides an interface using graphs. Note
that since PETSc is just a library there is nothing stopping someone
from calingl ParMetis or any other library anyway they want in the same
code that uses PETSc.
    Barry
On Feb 21, 2009, at 9:30 AM, Yixun Liu wrote:
> Barry Smith wrote:
>> On Feb 21, 2009, at 8:40 AM, Yixun Liu wrote:
>>> Hi,
>>> ex2 give an example on how to partition using ParMETIS by inputing
>>> element graph and mesh. ParMETIS also provides function for
>>> partitioning
>>> without inputing graph. Does PETSc provide some interface for this?
>> I doubt it. How can one partition a graph without providing the
>> graph?
>> Barry
>>> Thanks.
>>> Yixun
> Mesh can produce graph by taking into account the fact two neighboring
> elements share same edge or surface, so we can let ParMETIS do it just
> providing mesh as input. ParMETIS provides a function named as
> ParMETIS_V3_PartMeshKway, which only takes a mesh as input.
> Internally,
> this function use a mesh-to-graph routine(section 3.2 ParMETIS
> manual).
