How to use PETSc with sunf90?
Svend Tollak Munkejord
stm-direct_reply at pvv.org
Fri Feb 13 01:31:05 CST 2009
On 2009-02-12, Satish Balay wrote:
> On Thu, 12 Feb 2009, Svend Tollak Munkejord wrote:
>> > But ideally - you should be using '--with-cc=suncc --wth-cxx=sunCC'
>> > with sunf90 [not gcc/g++].
>> I agree, but this gives:
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>> C++ compiler you provided with -with-cxx=sunCC does not work
>> configure.log contains things like
>> Possible ERROR while running linker: /usr/lib64/libm.so: file not recognized: File format not recognized
>> and I don't know how to fix it. I could send you the configure.log if
>> you like.
> Hmm - sometimes sun compilers require the static libm - so the
> following additional option might
> work. '--LIBS=/usr/lib64/libm.a'.
As an option to ./config/configure.py ?
It made no difference.
> Otherwise - send us configure.log at
> petsc-maint at mcs.anl.gov
Based on your next e-mail (below), this now seems futile?
> Another note: we always recommend debug build of PETSc for
> development. One should worry about optimized/performance builds -
> only after developmenet is done and when performance numbers are
> captured [perhaps for publishing].
OK. I tried --with-debugging=yes, and it gave the same error message.
> Looks like sunCC is broken. [it can't compile a simple test
> code].
This is strange. I tried this on my 32-bit computer, and there sunCC
didn't seem to cause any trouble.
> This c++ dependency is from hypre..
Yes, the BoomerAMG solver works very well for my problems.
