How to use PETSc with sunf90?
Thu Feb 12 11:57:08 CST 2009
On Thu, 12 Feb 2009, Satish Balay wrote:
> On Thu, 12 Feb 2009, Svend Tollak Munkejord wrote:
> > > But ideally - you should be using '--with-cc=suncc --wth-cxx=sunCC'
> > > with sunf90 [not gcc/g++].
> > I agree, but this gives:
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > C++ compiler you provided with -with-cxx=sunCC does not work
> > configure.log contains things like
> > Possible ERROR while running linker: /usr/lib64/libm.so: file not recognized: File format not recognized
Looks like sunCC is broken. [it can't compile a simple test
code]. This c++ dependency is from hypre..
Satish
