PetscValidIntPointer() Re: DACreate2d() and DAGetMatrix()
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Thu Feb 12 16:08:51 CST 2009
Hi,all,
Where could I see the source code of PetscValidIntPointer()?
Rebecca
Quoting "(Rebecca) Xuefei YUAN" <xy2102 at columbia.edu>:
> I check the matrix.c and find that the x,y,z direction has been
> reversed as in line 1249-1252 in MatSetStencil(), can I get to know why
> we do this?
> Thanks.
> 1249:   for (i=0; i<dim; i++) {
> 1250:     mat->stencil.dims[i]   = dims[dim-i-1];      /* copy the
> values in backwards */
> 1251:     mat->stencil.starts[i] = starts[dim-i-1];
> 1252:   }
>> I think the dims should be {9,5,4,0} if it is Xperiodic, and should be
>> {5,9,4,0} if it is Yperiodic. Am I right?
>> Thanks,
>> Rebecca
>>> If I have -da_grid_x 5 -da_grid_y 5 -dmmg_nlevels 1 and the DA and
>>> jacobian like:
>>>>> ierr = DMMGCreate(comm, 1, &appCtx, &dmmg);CHKERRQ(ierr);
>>>>> ierr = DACreate2d(comm,DA_XPERIODIC,DA_STENCIL_STAR, -5, -5,
>>>>> PETSC_DECIDE, PETSC_DECIDE, 4, 2, 0, 0, &da);CHKERRQ(ierr);
>>>>> ierr = DMMGSetDM(dmmg, (DM)da);CHKERRQ(ierr);
>>>>> ierr = DAGetMatrix(DMMGGetDA(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
>>> will that be right if I have jacobian->stencil.dims ={5, 9, 4, 0}?
>>> Thanks,
>>> Rebecca
>>> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>>>> The dof argument to DACreate2d() is greater than 1. Thus the
>>>> "dimension" that is associated with the matrix is 3 dimensions.  Is
>>>> this causing a problem?
>>>> Barry
>>>> Note: the "dimension" of the matrix affects the MatSetValuesStencil()
>>>> but not much else I can think of;
>>>> On Feb 12, 2009, at 11:44 AM, (Rebecca) Xuefei YUAN wrote:
>>>>> Hi,
>>>>> I use the following set of codes to create the jacobian matrix,
>>>>>    however, the dimensions of jacobian becomes 3 (dim=3)
>>>>> although  I    use DACreate2d to create this da. I wanna know
>>>>> where is  wrong?
>>>>> Thanks very much!
>>>>> Rebecca
>>> Department of Applied Physics and Applied Mathematics
>>> Columbia University
>>> Tel:917-399-8032
>>> www.columbia.edu/~xy2102
>> Columbia University
>> Tel:917-399-8032
> Columbia University
> Tel:917-399-8032
Columbia University
Tel:917-399-8032
