DACreate2d() and DAGetMatrix()
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Thu Feb 12 14:53:13 CST 2009
I check the matrix.c and find that the x,y,z direction has been
reversed as in line 1249-1252 in MatSetStencil(), can I get to know
why we do this?
Thanks.
1249: for (i=0; i<dim; i++) {
1250: mat->stencil.dims[i] = dims[dim-i-1]; /* copy the
values in backwards */
1251: mat->stencil.starts[i] = starts[dim-i-1];
1252: }
Quoting "(Rebecca) Xuefei YUAN" <xy2102 at columbia.edu>:
> I think the dims should be {9,5,4,0} if it is Xperiodic, and should be
> {5,9,4,0} if it is Yperiodic. Am I right?
> Thanks,
> Rebecca
>> If I have -da_grid_x 5 -da_grid_y 5 -dmmg_nlevels 1 and the DA and
>> jacobian like:
>>>> ierr = DMMGCreate(comm, 1, &appCtx, &dmmg);CHKERRQ(ierr);
>>>> ierr = DACreate2d(comm,DA_XPERIODIC,DA_STENCIL_STAR, -5, -5,
>>>> PETSC_DECIDE, PETSC_DECIDE, 4, 2, 0, 0, &da);CHKERRQ(ierr);
>>>> ierr = DMMGSetDM(dmmg, (DM)da);CHKERRQ(ierr);
>>>> ierr = DAGetMatrix(DMMGGetDA(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
>> will that be right if I have jacobian->stencil.dims ={5, 9, 4, 0}?
>> Thanks,
>> Rebecca
>> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>>> The dof argument to DACreate2d() is greater than 1. Thus the
>>> "dimension" that is associated with the matrix is 3 dimensions. Is
>>> this causing a problem?
>>> Barry
>>> Note: the "dimension" of the matrix affects the MatSetValuesStencil()
>>> but not much else I can think of;
>>> On Feb 12, 2009, at 11:44 AM, (Rebecca) Xuefei YUAN wrote:
>>>> Hi,
>>>> I use the following set of codes to create the jacobian matrix,
>>>> however, the dimensions of jacobian becomes 3 (dim=3) although I
>>>> use DACreate2d to create this da. I wanna know where is wrong?
>>>> Thanks very much!
>>>> Rebecca
>> Department of Applied Physics and Applied Mathematics
>> Columbia University
>> Tel:917-399-8032
>> www.columbia.edu/~xy2102
> Columbia University
> Tel:917-399-8032
Columbia University
Tel:917-399-8032
