About the bug problem
Thu Feb 12 10:03:27 CST 2009
Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-cc=gcc --with-fc=gfortran --with-cxx=g++ --with-mpi=0 --with-x=0 --with-clanguage=cxx --with-shared=1 --with-dynamic=1 PETSC_ARCH=x86_64_linux_node2
We don't won't to flood mailing lists with huge attachments - so
emails with configure.log attachments will be blocked. [petsc-maint
would be the correct place for such e-mails].
In your case - if the code runs fine in debugger - but not directly -
it could mean some random memory corruption error.
Sugest using valgrind to narrow down the problem. i.e
valgrind --tool=memcheck -q binary
Satish
On Thu, 12 Feb 2009, Wei-Dong Lian wrote:
> Hello everyone,
> I am new for petsc. Thanks a lot for everyone working on petsc. It is really
> powerful and stable.
> I met a problem in using petsc. Below are the error information. But when I
> run this program under gdb degbuger, it worked. and the results are OK.
> I am attaching the configure.log and make.log of petsc.
> Can anyone give me some suggestions, I will be appreciated.
> Thanks a lot.
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSCERROR:
> or try
> http://valgrind.org on linux or man libgmalloc on Apple to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 3, Fri Jan 30 17:55:56
> CST 2009
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./main on a x86_64_li named node2.alineos.net by lian Thu
> Feb 12 16:23:38 2009
> [0]PETSC ERROR: Libraries linked from
> /glouton/struct/lian/develop-64/Solver/petscSeq/x86_64_linux_node2/lib
> [0]PETSC ERROR: Configure run at Thu Feb 12 11:20:04 2009
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown
> file
> /bin/sh: line 1: 27527 Aborted                 ./main data/main.dat
