make test
Tue Feb 10 19:06:37 CST 2009
There were no errors, just some compiler warnings.
 Matt
On Tue, Feb 10, 2009 at 5:31 PM, Yixun Liu <enjoywm at cs.wm.edu> wrote:
> Hi,
> I install petsc and make test, but there are some errors. I cannot find
> the solution in the troubleshooting.
> Running test examples to verify correct installation
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> MPI process
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
> MPI processes
> Graphics example src/snes/examples/tutorials/ex19 run successfully with
> 1 MPI process
> --------------Error detected during compile or link!-----------------------
> See http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
> mpif77 -c  -Wall -Wno-unused-variable -g
> -I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
> -I/home/scratch/yixun/petsc-3.0.0-p3/include -I/usr/include       -o
> ex5f.o ex5f.F
> Warning: Nonconforming tab character in column 1 of line 899
> Warning: Nonconforming tab character in column 1 of line 2818
> Warning: Nonconforming tab character in column 1 of line 4373
> Warning: Nonconforming tab character in column 1 of line 5927
> Warning: Nonconforming tab character in column 1 of line 7520
> mpif77 -Wall -Wno-unused-variable -g   -o ex5f ex5f.o
> -Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
> -L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lpetscsnes
> -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc   -lX11 -llapack
> -lblas -lm -L/usr/lib64 -L/usr/lib64/gcc/x86_64-suse-linux/4.2.1
> -L/lib64 -L/usr/x86_64-suse-linux/lib -ldl -llammpio -llamf77mpi -lmpi
> -llam -lutil -lgcc_s -lpthread -lgfortranbegin -lgfortran -lm -lm -ldl
> -llammpio -llamf77mpi -lmpi -llam -lutil -lgcc_s -lpthread -ldl
> /bin/rm -f ex5f.o
> Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
> MPI process
> Completed test examples
> Thanks.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
