make test
Yixun Liu enjoywm at cs.wm.edu
Tue Feb 10 17:31:50 CST 2009
I install petsc and make test, but there are some errors. I cannot find
the solution in the troubleshooting.
Running test examples to verify correct installation
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
MPI processes
Graphics example src/snes/examples/tutorials/ex19 run successfully with
1 MPI process
--------------Error detected during compile or link!-----------------------
See http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
mpif77 -c  -Wall -Wno-unused-variable -g
-I/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/include
-I/home/scratch/yixun/petsc-3.0.0-p3/include -I/usr/include       -o
ex5f.o ex5f.F
Warning: Nonconforming tab character in column 1 of line 899
Warning: Nonconforming tab character in column 1 of line 2818
Warning: Nonconforming tab character in column 1 of line 4373
Warning: Nonconforming tab character in column 1 of line 5927
Warning: Nonconforming tab character in column 1 of line 7520
mpif77 -Wall -Wno-unused-variable -g   -o ex5f ex5f.o
-Wl,-rpath,/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib
-L/home/scratch/yixun/petsc-3.0.0-p3/linux-gnu-c-debug/lib -lpetscsnes
-lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc   -lX11 -llapack
-lblas -lm -L/usr/lib64 -L/usr/lib64/gcc/x86_64-suse-linux/4.2.1
-L/lib64 -L/usr/x86_64-suse-linux/lib -ldl -llammpio -llamf77mpi -lmpi
-llam -lutil -lgcc_s -lpthread -lgfortranbegin -lgfortran -lm -lm -ldl
-llammpio -llamf77mpi -lmpi -llam -lutil -lgcc_s -lpthread -ldl
/bin/rm -f ex5f.o
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
MPI process
Completed test examples
Thanks.
