Performance degradation after upgrade to 3.0.0
Billy Araújo billy at dem.uminho.pt
Thu Feb 5 15:56:27 CST 2009
Matthew,
After all, the problem was mine. I had a bug in the code and I didn't notice it until this PETSc version.
Thanks once again.
Keep up the good work.
Billy.
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov on behalf of Billy Araújo
Sent: Thu 2/5/2009 10:04 AM
To: Matthew Knepley; PETSc users list
Cc: petsc-maint Maintenance
Subject: RE: Performance degradation after upgrade to 3.0.0
Thanks for the explanation.
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Wed 2/4/2009 10:46 PM
To: PETSc users list
Cc: petsc-maint Maintenance; Billy Araújo
Subject: Re: Performance degradation after upgrade to 3.0.0
On Tue, Feb 3, 2009 at 4:35 PM, Billy Araujo <billyaraujo at gmail.com> wrote:
> "Can you send the matrix and rhs as PETSc binary output, and I will find out
> what the difference is. It looks to me like the default ICC ordering
> has changed.
Okay, I have the explanation. The default factorization options
changed in 3.0.0.
No, by default, we use a diagonal shift to remedy zero diagonal elements, like
  -pc_factor_shift_positive_definite TRUE
You do not have a zero per se, but you do have a singular matrix, which you can
check using -ksp_type preonly -pc_type lu, so the last row has a zero diagonal.
Since nothing is ever divided by it, it causes no problems if you do
nothing. However,
shifting generates a much poorer preconditioner. You can recover the original
behavior using
  -pc_factor_shift_positive_definite FALSE
However, I would also advise uncovering the source of the singularity.
     Matt
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
Name: not available
Type: application/ms-tnef
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090205/207267f8/attachment.bin>
