Performance degradation after upgrade to 3.0.0
Billy Araújo billy at dem.uminho.pt
Thu Feb 5 04:04:39 CST 2009
Thanks for the explanation.
-----Original Message-----
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Wed 2/4/2009 10:46 PM
To: PETSc users list
Cc: petsc-maint Maintenance; Billy Araújo
Subject: Re: Performance degradation after upgrade to 3.0.0
On Tue, Feb 3, 2009 at 4:35 PM, Billy Araujo <billyaraujo at gmail.com> wrote:
> "Can you send the matrix and rhs as PETSc binary output, and I will find out
> what the difference is. It looks to me like the default ICC ordering
> has changed.
Okay, I have the explanation. The default factorization options
changed in 3.0.0.
No, by default, we use a diagonal shift to remedy zero diagonal elements, like
  -pc_factor_shift_positive_definite TRUE
You do not have a zero per se, but you do have a singular matrix, which you can
check using -ksp_type preonly -pc_type lu, so the last row has a zero diagonal.
Since nothing is ever divided by it, it causes no problems if you do
nothing. However,
shifting generates a much poorer preconditioner. You can recover the original
behavior using
  -pc_factor_shift_positive_definite FALSE
However, I would also advise uncovering the source of the singularity.
     Matt
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090205/d8a86054/attachment.htm>
