compiling PETSc with Intel MKL 10.0.1.14
Randall Mackie
rlmackie862 at gmail.com
Wed Feb 4 12:25:16 CST 2009
Hi Satish,
I can now confirm that even though I get those warning messages
when I link my code, that it runs properly on my test models.
Thanks for your help and clarifications.
Randy
Satish Balay wrote:
> Ok - for one you are on a x86_64 machine. So
> --with-blas-lapack-dir=/opt/intel/mkl/10.0.3.020/lib/64 is incorrect.
> --with-blas-lapack-dir=/opt/intel/mkl/10.0.3.020/lib/em64t would be
> the correct thing [or --with-blas-lapack-dir=/opt/intel/mkl/10.0.3.020
> - so that configure determines the correct subdir in lib]
> Note: intel calls 'x86_64' [i.e AMD64] as 'em64t', and IA64 [i.e itanium] as '64'
> However currently you get link time warnings. The exectuable gets
> created - so it should run correctly. Can you confirm this? [I don't
> see any errors in the output you sent.]
> And I don't think you'll be able to get rid of these warnings. Your
> compiler is already configured to look into both locations.
> run 'mpicc -v foo.c' [on any simple c code] - and you'll see the
> following link paths.
> "-L/opt/intel/mkl/10.0.3.020/lib/64" "-L/opt/intel/mkl/10.0.3.020/lib/em64t"
> [It should not be linking agaings '64' version. It should only use 'em64t' version]
> Satish
> On Tue, 3 Feb 2009, Randall Mackie wrote:
>> Hi Satish,
>> I compiled PETSC with the following options:
>> ./configure PETSC_ARCH=linux-intel-opt --with-fortran-kernels=generic
>> =/opt/intel/mkl/10.0.3.020/lib/64 --with-scalar-type=complex
>> --with-debugging=0
>> PETSc compiled just fine, but when I tried to compile my application, or run
>> the tests
>> within PETSC, it bombed out looking for the MKL libraries like:
>> mpif90 -O -o d3inv_DA_1_1_4_petsc ... ,-rpath,/opt/intel/mkl/
>> 10.0.3.020/lib/64 -L/opt/intel/mkl/10.0.3.020/lib/64 -lmkl_lapack -lmkl
>> -lguide -lpthread -lPEPCF9r/lib64 -L/usr/mpi/intel/mvapich-1.0.1/lib/shared
>> -L/usr/mpi/intel/mvapich-1.0.1/lib -ldl -lmpich -libverbs -libumad
>> -libcommon -lpthread -lrt -L/opt/intel/mkl/
>> 10.0.3.020/libopt/intel/mkl/10.0.3.020/lib/em64t ......
>> ld: skipping incompatible
>> /opt/intel/mkl/10.0.3.020/lib/64/libmkl_lapack.sowhen searching for
>> -lmkl_lapack
>> etc.
>> I'll try Paul's method of specifying the exact libraries to be included. If
>> you want, I can
>> still send you the configure log.
>> Randy
>> On Tue, Feb 3, 2009 at 3:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> I just successfully compiled petsc-dev [which is almost same as
>>> petsc-3.0.0-p3] & MLK successfully with both intel & gnu compilers.
>>> ./configure
>>> --with-blas-lapack-dir=/gfs/software/software/intel/compilersuite/10.1/mkl/10.0.011
>>> --with-mpi=0 PETSC_ARCH=linux-mkl
>>> ./configure
>>> --with-mpi=0 PETSC_ARCH=linux-icc-mkl CC=icc FC=ifort
>>> What problems are you encountering? Send configure.log to petsc-maint..
>>> Satish
>>>> Paul,
>>>> Have you tried this with Petsc 3.0.0? I just tried to compile it using
>>>> MKL 10.0.3.020, and I am having the same issue you specified below, in
>>> that
>>>> Petsc is looking for -lmkl_lapack -lmkl -lguide etc and the compilation
>>>> doesn't work.
>>>> Randy
>>>> Paul T. Bauman wrote:
>>>>> Sorry this took so long to get around to doing. So it turns out that
>>> there's
>>>>> a newer version of 2.3.3p13 posted at the PETSc ftp server. This worked
>>>>> flawlessly with the new MKL. I guess it got fixed and checked-in, but
>>> not
>>>>> under a new patch?
>>>>> Thanks,
>>>>> Paul
>>>>> Barry Smith wrote:
>>>>>> Please send the configure.log to petsc-maint at mcs.anl.gov
>>>>>> Barry
>>>>>> On Aug 15, 2008, at 1:39 PM, Paul T. Bauman wrote:
>>>>>>> Was there ever a fix/workaround introduced for this? I'm using
>>> 2.3.3p13
>>>>>>> and I'm having trouble getting the config to recognize mkl
>>> 10.0.3.020.
>>>>>>> Thanks,
>>>>>>> Paul
>>>>>>> Barry Smith wrote:
>>>>>>>> Could you email to petsc-maint at mcs.anl.gov ALL the messages as
>>> to
>>>>>>>> what goes wrong with
>>>>>>>> our current linking so we can fix it?
>>>>>>>> Thanks
>>>>>>>> Barry
>>>>>>>> On Jun 18, 2008, at 3:32 PM, Randall Mackie wrote:
>>>>>>>>> We've upgraded Intel MKL to version 10.0, but in this version,
>>> Intel
>>>>>>>>> has
>>>>>>>>> changed how libraries are suppose to be linked. For example,
>>> the
>>>>>>>>> libmkl_lapack.a
>>>>>>>>> is a dummy library, but that's what the PETSc configure script
>>> looks
>>>>>>>>> for.
>>>>>>>>> The documentation says, for example, to compile LAPACK in the
>>> static
>>>>>>>>> case,
>>>>>>>>> use libmkl_lapack.a libmkl_em64t.a
>>>>>>>>> and in the layered pure case to use
>>>>>>>>> libmkl_intel_lp64.a libmkl_intel_thread.a libmkl_core.a
>>>>>>>>> However, the PETSC configuration wants -lmkl_lapack -lmkl
>>> -lguide
>>>>>>>>> -lpthread
>>>>>>>>> Any suggestions are appreciated.
>>>>>>>>> Randy
