compiling PETSc with Intel MKL 10.0.1.14
    Satish Balay
    balay at mcs.anl.gov
    Tue Feb  3 21:07:06 CST 2009
On Tue, 3 Feb 2009, Randall Mackie wrote:
> Do you have an idea of how much difference there is in computation times
> using the Intel MKL optimized libraries versus just having PETSc download
> and compile them itself?
Well - petsc primarily uses blas1. And depending upon the
application's usage of PETSc - blas could be a reasonable part - but
not dominant part of the total run-time.
So a higher performance blas should make at most a few percentage
points [ perhaps less than 10%] improvement on the total
runtime. Typically - it could be much less than that..
-log_summary would be a good place to look at the performance
differences..
Satish
