compiling PETSc with Intel MKL 10.0.1.14
Randall Mackie
randy at geosystem.us
Tue Feb 3 16:03:53 CST 2009
Paul,
Have you tried this with Petsc 3.0.0? I just tried to compile it using
MKL 10.0.3.020, and I am having the same issue you specified below, in that
Petsc is looking for -lmkl_lapack -lmkl -lguide etc and the compilation
doesn't work.
Randy
Paul T. Bauman wrote:
> Sorry this took so long to get around to doing. So it turns out that
> there's a newer version of 2.3.3p13 posted at the PETSc ftp server. This
> worked flawlessly with the new MKL. I guess it got fixed and checked-in,
> but not under a new patch?
> Thanks,
> Paul
> Barry Smith wrote:
>> Please send the configure.log to petsc-maint at mcs.anl.gov
>> Barry
>> On Aug 15, 2008, at 1:39 PM, Paul T. Bauman wrote:
>>> Was there ever a fix/workaround introduced for this? I'm using
>>> 2.3.3p13 and I'm having trouble getting the config to recognize mkl
>>> 10.0.3.020.
>>> Thanks,
>>> Paul
>>> Barry Smith wrote:
>>>> Could you email to petsc-maint at mcs.anl.gov ALL the messages as to
>>>> what goes wrong with
>>>> our current linking so we can fix it?
>>>> Thanks
>>>> Barry
>>>> On Jun 18, 2008, at 3:32 PM, Randall Mackie wrote:
>>>>> We've upgraded Intel MKL to version 10.0, but in this version,
>>>>> Intel has
>>>>> changed how libraries are suppose to be linked. For example, the
>>>>> libmkl_lapack.a
>>>>> is a dummy library, but that's what the PETSc configure script
>>>>> looks for.
>>>>> The documentation says, for example, to compile LAPACK in the
>>>>> static case,
>>>>> use libmkl_lapack.a libmkl_em64t.a
>>>>> and in the layered pure case to use
>>>>> libmkl_intel_lp64.a libmkl_intel_thread.a libmkl_core.a
>>>>> However, the PETSC configuration wants -lmkl_lapack -lmkl -lguide
>>>>> -lpthread
>>>>> Any suggestions are appreciated.
>>>>> Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
