Performance degradation after upgrade to 3.0.0
Billy Araújo billy at dem.uminho.pt
Mon Feb 2 04:03:04 CST 2009
OK. I will try to send this ASAP.
Billy.
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov on behalf of Matthew Knepley
Sent: Sun 2/1/2009 9:29 PM
To: PETSc users list
Subject: Re: Performance degradation after upgrade to 3.0.0
Can you send the matrix and rhs as PETSc binary output, and I will find out
what the difference is. It looks to me like the default ICC ordering
has changed.
  Matt
On Sun, Feb 1, 2009 at 3:01 PM, Billy Araújo <billy at dem.uminho.pt> wrote:
> Hi,
> Here are the files that contain all the information below. You can see that the matrices are the same, unless I am missing something here. :)
> (I am resending them in compressed format).
> Regards,
> Billy.
> Sent: Sun 2/1/2009 6:07 PM
> In order to determine what is happening you first should:
>  1) Confirm that the solver setup is identical using -ksp_view for
> both versions
>  2) Determine that the matrices are identical. Output both matrices using
>      MatView() with a PetscBinaryViewer. You can diff the files, and
> you can also
>      solver both matrices using KSP ex10.
>  3) Look at the residuals using -ksp_monitor. If they are different, something
>      else has changed.
>  Matt
> On Sun, Feb 1, 2009 at 6:32 AM, Billy Araújo <billy at dem.uminho.pt> wrote:
>> Hi,
>> I have also verified that there has been a degradation of performance using
>> the new 3.0 version:
>> This is my function calling PETSc:
>>   KSP ksp;
>>   PC pc;
>>   KSPCreate (PETSC_COMM_WORLD, &ksp);
>>   KSPSetOperators (ksp, *A, *A, DIFFERENT_NONZERO_PATTERN);
>>   KSPSetType (ksp, KSPFGMRES);
>>   KSPGetPC (ksp, &pc);
>>   PCSetType (pc, PrecondProc);
>>   KSPSetInitialGuessNonzero (ksp, PETSC_TRUE);
>>   KSPSetTolerances (ksp, 1E-50, maxtol, PETSC_DEFAULT, maxiter);
>>   KSPSetFromOptions (ksp);
>>   KSPSolve (ksp, *b, *x);
>>   KSPGetIterationNumber (ksp, iter);
>>   KSPGetResidualNorm (ksp, res);
>>   KSPDestroy (ksp);
>> with previous version 2.3.3-p6:
>> Number of iterations: 42 Residual: +7.073781E-13 Time: +8.615024E-03
>> now:
>> Number of iterations: 500 Residual: +2.746161E-05 Time: +1.026870E-01
>> It is reaching maximum number of iterations. The only thing I changed was:
>> MatSetOption (*A, MAT_SYMMETRIC);
>>  to
>> MatSetOption (*A, MAT_SYMMETRIC, PETSC_TRUE);
>> I think I didn't change anything else.
>> Regards,
>> Billy.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
-- Norbert Wiener
Name: not available
Type: application/ms-tnef
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090202/c4a45639/attachment.bin>
