[petsc-users] installation problems in mac machine
Mon Dec 21 18:32:40 CST 2009
   Please send this type of report to petsc-maint at mcs.anl.gov not
petsc-users
   Please send configure.log and make.log to petsc-maint at mcs.anl.gov
     Barry
On Dec 21, 2009, at 3:34 PM, hxie at umn.edu wrote:
> When I run "make all", I saw many warnings like
> f90_fwrap.F:124.72:
>     subroutine
> F90Array2dCreateScalar
> (array
> ,start1
> ,len1
> ,        1
> Warning: Line truncated at (1)
> f90_fwrap.F:130.72:
>     real(kind=selected_real_kind(10)),
> target ::                      ---
> It seems the it does not support f90. I smell something wrong, am I
> right? I installed the xcode and gfortran in the mac machine.
> On Dec 21 2009, petsc-users-request at mcs.anl.gov wrote:
>> Send petsc-users mailing list submissions to
>> 	petsc-users at mcs.anl.gov
>> To subscribe or unsubscribe via the World Wide Web, visit
>> 	https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> 	petsc-users-owner at mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of petsc-users digest..."
>> Today's Topics:
>>  1. installation problems in mac machine (hxie at umn.edu)
>>  2. Re: installation problems in mac machine (Satish Balay)
>>  3. Re: installation problems in mac machine (Dominik Szczerba)
>>  4. Re: installation problems in mac machine (Matthew Knepley)
>>  5. Re: installation problems in mac machine (Satish Balay)
>>  6. Re: installation problems in mac machine (Dominik Szczerba)
>>  7. Re: installation problems in mac machine (Matthew Knepley)
>> Message: 1
>> Date: 21 Dec 2009 15:04:59 -0600
>> From: hxie at umn.edu
>> Subject: installation problems in mac machine
>> To: petsc-users at mcs.anl.gov
>> Message-ID: <Gophermail.2.0.0912211504590.28258 at vs-w.tc.umn.edu>
>> Content-Type: text/plain; format=flowed; charset=UTF-8
>> Hi,
>> My operation system is Mac OS X 10.6.2. I unzip the petsc under /
>> usr/local/petsc-3.0.0-p10.
>> I use the following to configure petsc.
>> sudo ./config/configure.py --CFLAGS=-O3 --FFLAGS=-O3 --with-mpi-
>> dir=/usr/local/mpich2-1.2.1 --with-fortran --with-shared=0 --with-
>> fc=gfortran
>> And I run the following commands:
>> export PETS_ARCH=darwin10.2.0-c-debug;
>> PETSC_DIR=/usr/local/petsc-3.0.0-p10; export PETSC_DIR
>> When I run " sudo make all", it gives some errors:
>> makefile:15: /conf/base: No such file or directory
>> makefile:16: /conf/test: No such file or directory
>> make: *** No rule to make target `/conf/test'.  Stop.
>> It seems it cannot find the PETSC_DIR. (I use x11. "echo $SHELL"
>> gets "/bin/bash")
>> Do I need to add "PETSC_DIR = /usr/local/petsc-3.0.0-p10" in the
>> makefile file? Thanks.
>> Bests,
>> Hui
>> Message: 2
>> Date: Mon, 21 Dec 2009 15:10:00 -0600 (CST)
>> From: Satish Balay <balay at mcs.anl.gov>
>> Subject: Re: installation problems in mac machine
>> To: PETSc users list <petsc-users at mcs.anl.gov>
>> Message-ID: <alpine.LFD.2.00.0912211507000.2266 at asterix>
>> Content-Type: TEXT/PLAIN; charset=US-ASCII
>> Perhaps 'sudo' is not proegating PETSC_DIR,PETSC_ARCH variables
>> properly?
>> Try 'sudo /bin/bash' and do the whole install in that shell.
>> BTW: you have a typo with PETSC_ARCH further down..  And we recommend
>> using COPTFLAGS, FOPTFLAGS --with-debugging=0 for optimziation
>> builds.
>> Satish
>> On Mon, 21 Dec 2009, hxie at umn.edu wrote:
>>> Hi,
>>> /usr/local/petsc-3.0.0-p10.
>>> --with-mpi-dir=/usr/local/mpich2-1.2.1 --with-fortran --with-
>>> shared=0
>>> --with-fc=gfortran
>>> gets
>>> "/bin/bash")
>>> makefile
>>> file? Thanks.
>>> Bests,
>>> Hui
>> Message: 3
>> Date: Mon, 21 Dec 2009 22:13:56 +0100
>> From: Dominik Szczerba <dominik at itis.ethz.ch>
>> Message-ID: <4B2FE514.2070900 at itis.ethz.ch>
>> Content-Type: text/plain; charset=US-ASCII
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Why use sudo in the first place?
>> I am not a mac user, but normally on unix sudo is the last thing you
>> want to use during everyday work (provided that you are at all
>> allowed
>> to use it).
>> Dominik
>>> properly?
>>> recommend
>>> builds.
>>> Satish
>>>> Hi,
>>>> shared=0
>>>> --with-fc=gfortran
>>>> gets
>>>> "/bin/bash")
>>>> makefile
>>>> file? Thanks.
>>>> Bests,
>>>> Hui
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> iEYEARECAAYFAksv5Q0ACgkQ/EBMh9bUuzJGugCgiCLXN7u5flIjSk2PRDEFMKRy
>> KfUAn1kP90FbNBvFZNsvkIjNnEv4ovJX
>> =KArD
>> -----END PGP SIGNATURE-----
>> Message: 4
>> Date: Mon, 21 Dec 2009 15:15:27 -0600
>> From: Matthew Knepley <knepley at gmail.com>
>> Message-ID:
>> 	<a9f269830912211315x3b732653ke6e9d6dee2130b6d at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> On Mon, Dec 21, 2009 at 3:13 PM, Dominik Szczerba <dominik at itis.ethz.ch
>>> Hash: SHA1
>>> allowed
>>> to use it).
>> Not sure why you would think that. In fact, sudo is the safe way to
>> do
>> things
>> and recommended for everyday usage.
>> Matt
>>> Dominik
>>> > properly?
>>> recommend
>>> builds.
>>> > Satish
>>> >> Hi,
>>> shared=0
>>> >> --with-fc=gfortran
>>> $SHELL" gets
>>> >> "/bin/bash")
>>> makefile
>>> >> file? Thanks.
>>> >> Bests,
>>> >> Hui
>>> =KArD
