installation problems in mac machine
hxie at umn.edu
hxie at umn.edu
Mon Dec 21 15:34:02 CST 2009
When I run "make all", I saw many warnings like
f90_fwrap.F:124.72:
subroutine F90Array2dCreateScalar(array,start1,len1,
1
Warning: Line truncated at (1)
f90_fwrap.F:130.72:
real(kind=selected_real_kind(10)), target ::
It seems the it does not support f90. I smell something wrong, am I right?
I installed the xcode and gfortran in the mac machine.
On Dec 21 2009, petsc-users-request at mcs.anl.gov wrote:
>Send petsc-users mailing list submissions to
> petsc-users at mcs.anl.gov
>To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
> petsc-users-owner at mcs.anl.gov
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of petsc-users digest..."
>Today's Topics:
> 1. installation problems in mac machine (hxie at umn.edu)
> 2. Re: installation problems in mac machine (Satish Balay)
> 3. Re: installation problems in mac machine (Dominik Szczerba)
> 4. Re: installation problems in mac machine (Matthew Knepley)
> 5. Re: installation problems in mac machine (Satish Balay)
> 6. Re: installation problems in mac machine (Dominik Szczerba)
> 7. Re: installation problems in mac machine (Matthew Knepley)
>Message: 1
>Date: 21 Dec 2009 15:04:59 -0600
>From: hxie at umn.edu
>Subject: installation problems in mac machine
>To: petsc-users at mcs.anl.gov
>Message-ID: <Gophermail.2.0.0912211504590.28258 at vs-w.tc.umn.edu>
>Content-Type: text/plain; format=flowed; charset=UTF-8
>Hi,
>My operation system is Mac OS X 10.6.2. I unzip the petsc under
>/usr/local/petsc-3.0.0-p10.
>I use the following to configure petsc.
> sudo ./config/configure.py --CFLAGS=-O3 --FFLAGS=-O3
>--with-mpi-dir=/usr/local/mpich2-1.2.1 --with-fortran --with-shared=0
>--with-fc=gfortran
>And I run the following commands:
>export PETS_ARCH=darwin10.2.0-c-debug;
>PETSC_DIR=/usr/local/petsc-3.0.0-p10; export PETSC_DIR
>When I run " sudo make all", it gives some errors:
>makefile:15: /conf/base: No such file or directory
>makefile:16: /conf/test: No such file or directory
>make: *** No rule to make target `/conf/test'. Stop.
>It seems it cannot find the PETSC_DIR. (I use x11. "echo $SHELL" gets
>"/bin/bash")
>Do I need to add "PETSC_DIR = /usr/local/petsc-3.0.0-p10" in the makefile
>file? Thanks.
>Bests,
>Hui
>Message: 2
>Date: Mon, 21 Dec 2009 15:10:00 -0600 (CST)
>From: Satish Balay <balay at mcs.anl.gov>
>Subject: Re: installation problems in mac machine
>To: PETSc users list <petsc-users at mcs.anl.gov>
>Message-ID: <alpine.LFD.2.00.0912211507000.2266 at asterix>
>Content-Type: TEXT/PLAIN; charset=US-ASCII
>Perhaps 'sudo' is not proegating PETSC_DIR,PETSC_ARCH variables
>properly?
>Try 'sudo /bin/bash' and do the whole install in that shell.
>BTW: you have a typo with PETSC_ARCH further down.. And we recommend
>using COPTFLAGS, FOPTFLAGS --with-debugging=0 for optimziation builds.
>Satish
>On Mon, 21 Dec 2009, hxie at umn.edu wrote:
>> Hi,
>> --with-fc=gfortran
>> "/bin/bash")
>> file? Thanks.
>> Bests,
>> Hui
>Message: 3
>Date: Mon, 21 Dec 2009 22:13:56 +0100
>From: Dominik Szczerba <dominik at itis.ethz.ch>
>Message-ID: <4B2FE514.2070900 at itis.ethz.ch>
>Content-Type: text/plain; charset=US-ASCII
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
>Why use sudo in the first place?
>I am not a mac user, but normally on unix sudo is the last thing you
>want to use during everyday work (provided that you are at all allowed
>to use it).
>Dominik
>> properly?
>> Satish
>>> Hi,
>>> --with-fc=gfortran
>>> "/bin/bash")
>>> makefile
>>> file? Thanks.
>>> Bests,
>>> Hui
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.4.9 (GNU/Linux)
>iEYEARECAAYFAksv5Q0ACgkQ/EBMh9bUuzJGugCgiCLXN7u5flIjSk2PRDEFMKRy
>KfUAn1kP90FbNBvFZNsvkIjNnEv4ovJX
>=KArD
>-----END PGP SIGNATURE-----
>Message: 4
>Date: Mon, 21 Dec 2009 15:15:27 -0600
>From: Matthew Knepley <knepley at gmail.com>
>Message-ID:
> <a9f269830912211315x3b732653ke6e9d6dee2130b6d at mail.gmail.com>
>Content-Type: text/plain; charset="iso-8859-1"
> On Mon, Dec 21, 2009 at 3:13 PM, Dominik Szczerba
>> Hash: SHA1
>> to use it).
>Not sure why you would think that. In fact, sudo is the safe way to do
>things
>and recommended for everyday usage.
> Matt
>> Dominik
>> > properly?
>> > Satish
>> >> Hi,
>> >> --with-fc=gfortran
>> >> "/bin/bash")
>> makefile
>> >> file? Thanks.
>> >> Bests,
>> >> Hui
>> =KArD
