Mesh resolution
Ryan Yan vyan2000 at gmail.com
Tue Dec 15 21:42:10 CST 2009
Hi Rebecca,
Thanks for reminding me the half-spacing strategy, the 3*7 restriction
matrix in 1-D.
Yan
On Tue, Dec 15, 2009 at 10:37 PM, (Rebecca) Xuefei YUAN <xy2102 at columbia.edu
> wrote:
> Now PETSc treats the multigrid based on the half spacing strategy, thus
> they always do odd number of grids.
> R
> Quoting Ryan Yan <vyan2000 at gmail.com>:
>  Sorry, I forgot to cc to the group.
>> BTW, if this is designed to have only odd number of points on the finer
>> level grid, can anyone provide a hint on the reasoning behind this?
>> Thanks a lot,
>> Yan
>> On Tue, Dec 15, 2009 at 10:09 PM, Ryan Yan <vyan2000 at gmail.com> wrote:
>>  Hi Rebecca,
>>> Thanks for the info. I noticed that rule; yet, it seems very difficult to
>>> bring up a finest grid with *even* number of pts.
>>> Yan
>>> On Tue, Dec 15, 2009 at 9:55 PM, (Rebecca) Xuefei YUAN <
>>> xy2102 at columbia.edu> wrote:
>>>  The relation between the coarser grid and finer grid is always half
>>>> spacing in either x-, y-, or z-direction.
>>>> Thus, for your finest grid being 257x257x257, you need a coarser grid of
>>>> 129x129x129 on the coarse grid if your level is 2.
>>>> Hope this is helpful.
>>>> R
>>>>  Hi All,
>>>>> I was ignoring the importance of fixing the mesh size.
>>>>> For instance, if I want to compare the effect of mesh sequencing on the
>>>>> solver, I will use one level with 256 pt on each direction in 2d, in
>>>>> the
>>>>> first run.
>>>>> My question is,  in the second run, how to set up the number of points
>>>>> on
>>>>> the coarsest grid and pre-fix the level of the grid so that DMMG
>>>>> can bring me the exact resolution of  256 pt on each direction on the
>>>>> finest
>>>>> grid. Only this way, the two different solver are solving the problem
>>>>> of
>>>>> the
>>>>> same
>>>>> size.
>>>>> Thanks a lot,
>>>>> Yan
>>>> Department of Applied Physics and Applied Mathematics
>>>> Columbia University
>>>> Tel:917-399-8032
>>>> www.columbia.edu/~xy2102 <http://www.columbia.edu/%7Exy2102>
> Columbia University
> Tel:917-399-8032
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091215/e26bdb12/attachment.htm>
