KSPPREONLY
Ryan Yan
vyan2000 at gmail.com
Mon Dec 14 22:24:31 CST 2009
Thanks a lot,
Yan
On Mon, Dec 14, 2009 at 11:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Yes
> On Dec 14, 2009, at 10:19 PM, Ryan Yan wrote:
> Hi, Barry,
>> Thanks a lot.
>> So this is equivalent to using ksp richardson +pclu with 1 iteration on
>> the coarse grid, right?
>> Yan
>> On Mon, Dec 14, 2009 at 11:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> preonly means apply the preconditioner to the right hand side only, don't
>> do any iterations. Since LU is the preconditioner in this case preonly means
>> it is using LU as a direct solver.
>> On Dec 14, 2009, at 10:09 PM, Ryan Yan wrote:
>> Hi All,
>> I have the following output from -snes_view with the default snes
>> setting., but I don't know what the KSPPREONLY does on the coarse grid. Can
>> anyone provide some hints on this?
>> Assuming:
>> A_{coarse} * e_{coarse} =r _{coarse}
>> Thanks a lot,
>> Yan
>> SNES Object:
>> type: ls
>> line search variant: SNESLineSearchCubic
>> alpha=0.0001, maxstep=1e+08
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=32
>> total number of function evaluations=5
>> KSP Object:
>> type: fgmres
>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> GMRES: happy breakdown tolerance 1e-30
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
>> right preconditioning
>> PC Object:
>> type: mg
>> MG: type is FULL, levels=2 cycles=v
>> Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
>> KSP Object:(mg_coarse_)
>> type: preonly
>> maximum iterations=1, initial guess is zero
>> left preconditioning
>> PC Object:(mg_coarse_)
>> type: lu
>> LU: out-of-place factorization
>> matrix ordering: nd
>> LU: tolerance for zero pivot 1e-12
>> LU: factor fill ratio needed 5.02244
>> Factored matrix follows
>> Matrix Object:
>> type=seqaij, rows=4096, cols=4096
>> package used to perform factorization: petsc
>> total: nonzeros=401152, allocated nonzeros=401152
>> using I-node routines: found 1024 nodes, limit used is 5
>> linear system matrix = precond matrix:
>> Matrix Object:
>> total: nonzeros=79872, allocated nonzeros=79872
>> Down solver (pre-smoother) ......
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091214/4729b5d9/attachment.htm>
