KSPPREONLY
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 14 22:23:34 CST 2009
Yes
On Dec 14, 2009, at 10:19 PM, Ryan Yan wrote:
> Hi, Barry,
> Thanks a lot.
> So this is equivalent to using ksp richardson +pclu with 1 iteration
> on the coarse grid, right?
> Yan
> On Mon, Dec 14, 2009 at 11:16 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> preonly means apply the preconditioner to the right hand side only,
> don't do any iterations. Since LU is the preconditioner in this case
> preonly means it is using LU as a direct solver.
> On Dec 14, 2009, at 10:09 PM, Ryan Yan wrote:
> Hi All,
> I have the following output from -snes_view with the default snes
> setting., but I don't know what the KSPPREONLY does on the coarse
> grid. Can anyone provide some hints on this?
> Assuming:
> A_{coarse} * e_{coarse} =r _{coarse}
> Thanks a lot,
> Yan
> SNES Object:
> type: ls
> line search variant: SNESLineSearchCubic
> alpha=0.0001, maxstep=1e+08
> maximum iterations=50, maximum function evaluations=10000
> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> total number of linear solver iterations=32
> total number of function evaluations=5
> KSP Object:
> type: fgmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> right preconditioning
> PC Object:
> type: mg
> MG: type is FULL, levels=2 cycles=v
> Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
> KSP Object:(mg_coarse_)
> type: preonly
> maximum iterations=1, initial guess is zero
> left preconditioning
> PC Object:(mg_coarse_)
> type: lu
> LU: out-of-place factorization
> matrix ordering: nd
> LU: tolerance for zero pivot 1e-12
> LU: factor fill ratio needed 5.02244
> Factored matrix follows
> Matrix Object:
> type=seqaij, rows=4096, cols=4096
> package used to perform factorization: petsc
> total: nonzeros=401152, allocated nonzeros=401152
> using I-node routines: found 1024 nodes, limit used
> is 5
> linear system matrix = precond matrix:
> Matrix Object:
> total: nonzeros=79872, allocated nonzeros=79872
> using I-node routines: found 1024 nodes, limit used is 5
> Down solver (pre-smoother) ......
