KSPPREONLY
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 14 22:16:02 CST 2009
preonly means apply the preconditioner to the right hand side only,
don't do any iterations. Since LU is the preconditioner in this case
preonly means it is using LU as a direct solver.
On Dec 14, 2009, at 10:09 PM, Ryan Yan wrote:
> Hi All,
> I have the following output from -snes_view with the default snes
> setting., but I don't know what the KSPPREONLY does on the coarse
> grid. Can anyone provide some hints on this?
> Assuming:
> A_{coarse} * e_{coarse} =r _{coarse}
> Thanks a lot,
> Yan
> SNES Object:
> type: ls
> line search variant: SNESLineSearchCubic
> alpha=0.0001, maxstep=1e+08
> maximum iterations=50, maximum function evaluations=10000
> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> total number of linear solver iterations=32
> total number of function evaluations=5
> KSP Object:
> type: fgmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> right preconditioning
> PC Object:
> type: mg
> MG: type is FULL, levels=2 cycles=v
> Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
> KSP Object:(mg_coarse_)
> type: preonly
> maximum iterations=1, initial guess is zero
> left preconditioning
> PC Object:(mg_coarse_)
> type: lu
> LU: out-of-place factorization
> matrix ordering: nd
> LU: tolerance for zero pivot 1e-12
> LU: factor fill ratio needed 5.02244
> Factored matrix follows
> Matrix Object:
> type=seqaij, rows=4096, cols=4096
> package used to perform factorization: petsc
> total: nonzeros=401152, allocated nonzeros=401152
> using I-node routines: found 1024 nodes, limit
> used is 5
> linear system matrix = precond matrix:
> Matrix Object:
> total: nonzeros=79872, allocated nonzeros=79872
> using I-node routines: found 1024 nodes, limit used is 5
> Down solver (pre-smoother) ......
