KSPPREONLY
Ryan Yan
vyan2000 at gmail.com
Mon Dec 14 22:09:44 CST 2009
Hi All,
I have the following output from -snes_view with the default snes setting.,
but I don't know what the KSPPREONLY does on the coarse grid. Can anyone
provide some hints on this?
Assuming:
A_{coarse} * e_{coarse} =r _{coarse}
Thanks a lot,
Yan
SNES Object:
type: ls
line search variant: SNESLineSearchCubic
alpha=0.0001, maxstep=1e+08
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
total number of linear solver iterations=32
total number of function evaluations=5
KSP Object:
type: fgmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
right preconditioning
PC Object:
type: mg
MG: type is FULL, levels=2 cycles=v
Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
KSP Object:(mg_coarse_)
type: preonly
maximum iterations=1, initial guess is zero
left preconditioning
PC Object:(mg_coarse_)
type: lu
LU: out-of-place factorization
matrix ordering: nd
LU: tolerance for zero pivot 1e-12
LU: factor fill ratio needed 5.02244
Factored matrix follows
Matrix Object:
type=seqaij, rows=4096, cols=4096
package used to perform factorization: petsc
total: nonzeros=401152, allocated nonzeros=401152
using I-node routines: found 1024 nodes, limit used is 5
linear system matrix = precond matrix:
Matrix Object:
total: nonzeros=79872, allocated nonzeros=79872
Down solver (pre-smoother) ......
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091214/2f631eb6/attachment.htm>
