Which way to decompose domain/grid
Stephen Wornom stephen.wornom at sophia.inria.fr
Thu Dec 10 05:55:13 CST 2009
Wee-Beng Tay wrote:
> Hi,
> I'm working on a 2D Cartesian grid and I'm going to decompose the grid
> for MPI for my CFD Fortran code. The grid size is in the ratio of 110
> x 70. I wonder how I should decompose the grid - horizontally or
> vertically?
> For e.g., for 2 processors, to 2 55x70 grids, or 2 110x35 grids.
> I thought that communication between grids will be less if I do 55x70
> because communication will only involve 70 values.
I wrote a Cartesian mesh partitioner that partitions in slices as it
involves the minimum communication time.
For general meshes I partition with METIS. Question: I would like to use
the PETSC partitioner if use one has the option to partition on in the
x-y coordinates. Is that possible?
Hope my question is clear.
Stephen
> However, if it's 110x35, it'll involve 110 values
> Hence does it matter in PETSc how the decomposition is done?
> On the other hand, since Fortran is column major and hence I do the
> calculation:
> do j=1,size_y
> do i=1,size_x
> f(i,j)=....
> end do
> end do
> I'll need to "package" the 70 values in a chunk for efficient sending.
> However, if it's in 110x35, I can use mpi_isend directly since it's
> contagious data.
> So is there a better option since there seems to be a conflict? I read
> about the use of DMMG. Will this problem be dealt with much better if
> I use DMMG instead?
> Thank you very much
2004 route des lucioles - BP93
Sophia Antipolis
06902 CEDEX
Tel: 04 92 38 50 54
Fax: 04 97 15 53 51
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091210/6334d2c2/attachment.vcf>
