parallel matrix multiplication ATA
Mon Dec 7 15:01:29 CST 2009
    First, change your code to use a call to MatPtAPSymbolic()
followed by a call to MatPtAPNumeric() and run (using PETSc ./
configured with the option --with-debugging=0) with the flag -info and
save all the output to a file. Then search that file for the string
"Use MatPtAP", from this you will find the best fill factor.
  The run it a second time with the option -log_summary and that "best
fill factor" A table will be printed, look at how much time in the
table is devoted to the symbolic and numeric part of the product and
the flop rate to see if it looks reasonable. Feel free to send that
out to petsc-maint at mcs.anl.gov and from that we can conjecture if
there is a way to speed it up enough to make ti worth new codeing.
    Barry
On Dec 7, 2009, at 12:58 PM, Lukasz Kaczmarczyk wrote:
> Hello,
> I have to multiply rectangular parallel matrix A by its transpose
> (ATA). Matrix A is computed as result of some non standard hybrid
> approximation method. Columns of the matrix are associated with
> tetrahedral faces, rows are associated with tetrahedral. In order to
> compute elements of matrix A interprocess communication is not
> needed. In addition faces are shared maximally with two processes,
> faces can have only two neighbour elements.
> I have created matrix A using MatCreateMPIAIJWithSplitArrays, and
> create matrix ATA using MatPtAP which some diagonal scaling. The
> time consuming part of my algorithm is construction of matrix ATA.
> I looking for advice, if its worth to write own problem tailored
> multiplication operator or is better way to speedup algorithm using
> standard PETSc functions.
> I looking forward for any advice.
> Kind regards,
> Lukasz
