extracting work vectors
Jed Brown jed at 59A2.org
Fri Dec 4 06:06:35 CST 2009
On Fri, 04 Dec 2009 12:51:27 +0100, jarunan at ascomp.ch wrote:
> Hi Jed,
> Thanks for the advice. I took a look in PCShellSetApplyRicharson() and
> its apply function.
> PetscErrorCode apply (PC pc,Vec b,Vec x,Vec r,PetscReal rtol,PetscReal
> abstol,PetscReal dtol,PetscInt maxits)
> b - right-hand-side
> x - current iterate
> r - work space
> 1. Can I use PCShellSetApplyRicharson() with KSPGMRES? or it is
> restrict only for Richardson solver.
Richardson only.
> 2. Is x equivalent to xin in PCShellSetApply(pc,apply(PC pc,Vec
> xin,Vec xout))?
No, preconditioning Richardson is a different beast entirely.
> 3. Are b vector is the right hand side specified by user and r the
> work vector in the iterations?
Yes, r is just work space, you are not required to use it.
It's unlikely that you actually want to use Richardson, you should write
apply(PC,Vec,Vec).
Jed
