Multigrid Questions
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Aug 26 15:36:48 CDT 2009
   Please run with
-ksp_monitor_true_residual -snes_monitor -
mg_levels_ksp_monitor_true_residua -mg_coarse_ksp_type gmres -
mg_coarse_ksp_monitor_true_residual -snes_view
and send the output for one time-step.
    Barry
On Aug 26, 2009, at 2:34 PM, Hal Finkel wrote:
> Hello,
> I've constructed a evolution scheme for a time-dependent 3D PDE
> system using the DMMG layer. The core of the code is essentially a
> loop around DMMGSolve in the spirit of snes/examples/tutorials/
> ex29.c. If I only run with one level, then the code runs and
> produces sensible results. Passing the option -mg_levels_0_ksp_type
> bcgsl increases the solver speed by about 30%, and -
> mg_levels_0_pc_type fieldsplit gives me another 5% improvement. Does
> that say something about the structure of my problem?
> If I run with two levels, the coarse solve seems to work, but the
> fine grid's KSP never seems to complete. If I run with -
> mg_levels_1_ksp_monitor_true_residual, I can see the residual does
> not seem to be converging at all:
>      0 KSP preconditioned resid norm 1.979915874387e+02 true resid
> norm 1.889855551272e+04 ||Ae||/||Ax|| 1.889855551272e+04
>      0 KSP preconditioned resid norm 3.833279709488e+06 true resid
> norm 3.665290817713e+08 ||Ae||/||Ax|| 3.665290817713e+08
>      0 KSP preconditioned resid norm 5.080465654647e+01 true resid
> norm 8.284057252719e+03 ||Ae||/||Ax|| 8.284057252719e+03
>      1 KSP preconditioned resid norm 6.057649668915e+00 true resid
> norm 5.136009463814e+02 ||Ae||/||Ax|| 5.136009463814e+02
>      0 KSP preconditioned resid norm 5.511785811223e+04 true resid
> norm 1.055162492334e+07 ||Ae||/||Ax|| 1.055162492334e+07
>      0 KSP preconditioned resid norm 2.164672340919e+01 true resid
> norm 2.999406329054e+04 ||Ae||/||Ax|| 2.999406329054e+04
>      0 KSP preconditioned resid norm 5.275983407134e+05 true resid
> norm 9.196351032040e+08 ||Ae||/||Ax|| 9.196351032040e+08
>      0 KSP preconditioned resid norm 3.338344860439e+01 true resid
> norm 5.133553722923e+03 ||Ae||/||Ax|| 5.133553722923e+03
>      1 KSP preconditioned resid norm 4.306407436023e+00 true resid
> norm 3.361745947223e+02 ||Ae||/||Ax|| 3.361745947223e+02
> If I run with -pc_mg_monitor I see, after the course solve, only
> things like:
>    Residual norms for mg_levels_1_ solve.
>    0 KSP Residual norm 1.979915874387e+02
>    0 KSP Residual norm 3.833279709488e+06
>    0 KSP Residual norm 5.080465654647e+01
>    1 KSP Residual norm 6.057649668915e+00
>    0 KSP Residual norm 5.511785811223e+04
>    0 KSP Residual norm 2.164672340919e+01
>    0 KSP Residual norm 5.275983407134e+05
>    0 KSP Residual norm 3.338344860439e+01
>    1 KSP Residual norm 4.306407436023e+00
> running with -info shows:
> [0] KSPDefaultConverged(): user has provided nonzero initial guess,
> computing 2-norm of preconditioned RHS
> [0] KSPDefaultConverged(): Linear solver is diverging. Initial right
> hand size norm 0.0066162, current residual norm 23282.7 at iteration 0
> hand size norm 0.00287711, current residual norm 38.2205 at
> iteration 0
> hand size norm 0.00287711, current residual norm 809191 at iteration 0
> hand size norm 0.00970186, current residual norm 186.983 at
> iteration 0
> hand size norm 0.00970186, current residual norm 3.62292e+06 at
> iteration 0
> What is a good way to debug this?
> No matter how I run, I've arranged the code so that the fine grid is
> *always* the same size; it has to be because the initial conditions
> are loaded from a file.
> In general, however, I don't understand exactly what the mg
> preconditioner is doing. Is there a writeup somewhere which is more
> verbose than the manual? In the one-level case, how are the results
> of the solve used to precondition the Jacobian?
> In an 1-processor, 1-level case, running with -snes_view gives:
> SNES Object:
>  type: ls
>    line search variant: SNESLineSearchCubic
>    alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>  maximum iterations=50, maximum function evaluations=10000
>  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>  total number of linear solver iterations=36
>  total number of function evaluations=3
>  KSP Object:
>    type: fgmres
>      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>      GMRES: happy breakdown tolerance 1e-30
>    maximum iterations=10000, initial guess is zero
>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>    right preconditioning
>  PC Object:
>    type: mg
>      MG: type is FULL, levels=1 cycles=v
>    Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
>      KSP Object:(mg_levels_0_)
>        type: bcgsl
>          BCGSL: Ell = 2
>          BCGSL: Delta = 0
>        maximum iterations=1, initial guess is zero
>        left preconditioning
>      PC Object:(mg_levels_0_)
>        type: fieldsplit
>          FieldSplit with MULTIPLICATIVE composition: total splits =
> 2, blocksize = 2
>          Solver info for each split is in the following KSP objects:
>          Split number 0 Fields  0
>          KSP Object:(mg_levels_0_fieldsplit_0_)
>            type: preonly
> divergence=10000
>          PC Object:(mg_levels_0_fieldsplit_0_)
>            type: ilu
>              ILU: 0 levels of fill
>              ILU: factor fill ratio allocated 1
>              ILU: tolerance for zero pivot 1e-12
>              ILU: using diagonal shift to prevent zero pivot
>              ILU: using diagonal shift on blocks to prevent zero pivot
>                   out-of-place factorization
>                   matrix ordering: natural
>              ILU: factor fill ratio needed 1
>                   Factored matrix follows
>                  Matrix Object:
>                    type=seqaij, rows=19683, cols=19683
>                    package used to perform factorization: petsc
>                    total: nonzeros=531441, allocated nonzeros=531441
>                      not using I-node routines
>            linear system matrix = precond matrix:
>            Matrix Object:
>          Split number 1 Fields  1
>          KSP Object:(mg_levels_0_fieldsplit_1_)
>            type: preonly
> divergence=10000
>          PC Object:(mg_levels_0_fieldsplit_1_)
>            type: ilu
>                  Matrix Object:
>            Matrix Object:
>        Matrix Object:
>          type=seqaij, rows=39366, cols=39366
>          total: nonzeros=2125764, allocated nonzeros=2125764
>            using I-node routines: found 19683 nodes, limit used is 5
>    Matrix Object:
> Thank you in advance,
> Hal
