Multigrid Questions
    Hal Finkel
    hal.finkel at yale.edu
    Wed Aug 26 14:34:20 CDT 2009
Hello,
I've constructed a evolution scheme for a time-dependent 3D PDE system
using the DMMG layer. The core of the code is essentially a loop around
DMMGSolve in the spirit of snes/examples/tutorials/ex29.c. If I only run
with one level, then the code runs and produces sensible results.
Passing the option -mg_levels_0_ksp_type bcgsl increases the solver
speed by about 30%, and -mg_levels_0_pc_type fieldsplit gives me another
5% improvement. Does that say something about the structure of my problem?
If I run with two levels, the coarse solve seems to work, but the fine
grid's KSP never seems to complete. If I run with
-mg_levels_1_ksp_monitor_true_residual, I can see the residual does not
seem to be converging at all:
       0 KSP preconditioned resid norm 1.979915874387e+02 true resid
norm 1.889855551272e+04 ||Ae||/||Ax|| 1.889855551272e+04
       0 KSP preconditioned resid norm 3.833279709488e+06 true resid
norm 3.665290817713e+08 ||Ae||/||Ax|| 3.665290817713e+08
       0 KSP preconditioned resid norm 5.080465654647e+01 true resid
norm 8.284057252719e+03 ||Ae||/||Ax|| 8.284057252719e+03
       1 KSP preconditioned resid norm 6.057649668915e+00 true resid
norm 5.136009463814e+02 ||Ae||/||Ax|| 5.136009463814e+02
       0 KSP preconditioned resid norm 5.511785811223e+04 true resid
norm 1.055162492334e+07 ||Ae||/||Ax|| 1.055162492334e+07
       0 KSP preconditioned resid norm 2.164672340919e+01 true resid
norm 2.999406329054e+04 ||Ae||/||Ax|| 2.999406329054e+04
       0 KSP preconditioned resid norm 5.275983407134e+05 true resid
norm 9.196351032040e+08 ||Ae||/||Ax|| 9.196351032040e+08
       0 KSP preconditioned resid norm 3.338344860439e+01 true resid
norm 5.133553722923e+03 ||Ae||/||Ax|| 5.133553722923e+03
       1 KSP preconditioned resid norm 4.306407436023e+00 true resid
norm 3.361745947223e+02 ||Ae||/||Ax|| 3.361745947223e+02
If I run with -pc_mg_monitor I see, after the course solve, only things
like:
     Residual norms for mg_levels_1_ solve.
     0 KSP Residual norm 1.979915874387e+02
     0 KSP Residual norm 3.833279709488e+06
     0 KSP Residual norm 5.080465654647e+01
     1 KSP Residual norm 6.057649668915e+00
     0 KSP Residual norm 5.511785811223e+04
     0 KSP Residual norm 2.164672340919e+01
     0 KSP Residual norm 5.275983407134e+05
     0 KSP Residual norm 3.338344860439e+01
     1 KSP Residual norm 4.306407436023e+00
running with -info shows:
[0] KSPDefaultConverged(): user has provided nonzero initial guess,
computing 2-norm of preconditioned RHS
[0] KSPDefaultConverged(): Linear solver is diverging. Initial right
hand size norm 0.0066162, current residual norm 23282.7 at iteration 0
hand size norm 0.00287711, current residual norm 38.2205 at iteration 0
hand size norm 0.00287711, current residual norm 809191 at iteration 0
hand size norm 0.00970186, current residual norm 186.983 at iteration 0
hand size norm 0.00970186, current residual norm 3.62292e+06 at iteration 0
What is a good way to debug this?
No matter how I run, I've arranged the code so that the fine grid is
*always* the same size; it has to be because the initial conditions are
loaded from a file.
In general, however, I don't understand exactly what the mg
preconditioner is doing. Is there a writeup somewhere which is more
verbose than the manual? In the one-level case, how are the results of
the solve used to precondition the Jacobian?
In an 1-processor, 1-level case, running with -snes_view gives:
SNES Object:
   type: ls
     line search variant: SNESLineSearchCubic
     alpha=0.0001, maxstep=1e+08, minlambda=1e-12
   maximum iterations=50, maximum function evaluations=10000
   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
   total number of linear solver iterations=36
   total number of function evaluations=3
   KSP Object:
     type: fgmres
       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
       GMRES: happy breakdown tolerance 1e-30
     maximum iterations=10000, initial guess is zero
     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
     right preconditioning
   PC Object:
     type: mg
       MG: type is FULL, levels=1 cycles=v
     Coarse gride solver -- level 0 presmooths=1 postsmooths=1 -----
       KSP Object:(mg_levels_0_)
         type: bcgsl
           BCGSL: Ell = 2
           BCGSL: Delta = 0
         maximum iterations=1, initial guess is zero
         left preconditioning
       PC Object:(mg_levels_0_)
         type: fieldsplit
           FieldSplit with MULTIPLICATIVE composition: total splits = 2,
blocksize = 2
           Solver info for each split is in the following KSP objects:
           Split number 0 Fields  0
           KSP Object:(mg_levels_0_fieldsplit_0_)
             type: preonly
           PC Object:(mg_levels_0_fieldsplit_0_)
             type: ilu
               ILU: 0 levels of fill
               ILU: factor fill ratio allocated 1
               ILU: tolerance for zero pivot 1e-12
               ILU: using diagonal shift to prevent zero pivot
               ILU: using diagonal shift on blocks to prevent zero pivot
                    out-of-place factorization
                    matrix ordering: natural
               ILU: factor fill ratio needed 1
                    Factored matrix follows
                   Matrix Object:
                     type=seqaij, rows=19683, cols=19683
                     package used to perform factorization: petsc
                     total: nonzeros=531441, allocated nonzeros=531441
                       not using I-node routines
             linear system matrix = precond matrix:
             Matrix Object:
           Split number 1 Fields  1
           KSP Object:(mg_levels_0_fieldsplit_1_)
             type: preonly
           PC Object:(mg_levels_0_fieldsplit_1_)
             type: ilu
                   Matrix Object:
             Matrix Object:
         Matrix Object:
           type=seqaij, rows=39366, cols=39366
           total: nonzeros=2125764, allocated nonzeros=2125764
             using I-node routines: found 19683 nodes, limit used is 5
     Matrix Object:
Thank you in advance,
Hal
