porting petsc to a nec sx9 computer running under unix super ux
Tue Aug 11 21:54:40 CDT 2009
Try using --with-batch=1 and follow the sugested steps.
Looking at the sx6 config file - looks like the compilers used were
cc,f90,cxx - so perhaps the env was slightly different. [don't
remember if it was cross compile or not..]
One potential issue is: configure might not be able to auto-detect
c/fortran compiler libraries [needed for mixing c & fortran codes]. If
this is an issue - sugest using someting like:
--with-clib-autodetect=0
--with-fortranlib-autodetect=0
--with-cxxlib-autodetect=0
LIBS="-lf90sx -lf90sxe -lv90sxe -li90sx -lu90sx -lm90sx"
[Might have to modify LIBS argument to the correct c/fortran compiler library list]
If you encounter problems - send us configure.log at petsc-maint at mcs.anl.gov
Satish
On Tue, 11 Aug 2009, Joel Guerrero wrote:
> Hi Satish,
> Well basically I am having problems with the cross compilation, are there any instructions available about how to cross compile petsc on these platforms?.  I am using sx9 compilers (sxcc, sxc++, sxmpicc and so on).
> Thanks for your help,
> Joel
> ----- Original Message ----
> From: Satish Balay <balay at mcs.anl.gov>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Sent: Wednesday, August 12, 2009 4:29:26 AM
> Subject: Re: porting petsc to a nec sx9 computer running under unix super ux
> we had an old version - perhaps 2.2.x working on sx6. It has standard
> compilers with mpi and blas - so I'm guessing current petsc should
> work on sx9.
> If you encounter problems building on sx9 - then send us the error
> logs at petsc-maint at mcs.anl.gov
> Satish
> > Hi,
> > I wonder if somebody have experience in porting petsc to a nec sx9 computer?
> > Cheers,
> > joel
