porting petsc to a nec sx9 computer running under unix super ux
Tue Aug 11 21:49:48 CDT 2009
   Run ./configure with the additional option --with-batch and then
follow the directions
    Barry
On Aug 11, 2009, at 9:46 PM, Joel Guerrero wrote:
> Hi Satish,
> Well basically I am having problems with the cross compilation, are
> there any instructions available about how to cross compile petsc on
> these platforms?.  I am using sx9 compilers (sxcc, sxc++, sxmpicc
> and so on).
> Thanks for your help,
> Joel
> ----- Original Message ----
> From: Satish Balay <balay at mcs.anl.gov>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Sent: Wednesday, August 12, 2009 4:29:26 AM
> Subject: Re: porting petsc to a nec sx9 computer running under unix
> super ux
> we had an old version - perhaps 2.2.x working on sx6. It has standard
> compilers with mpi and blas - so I'm guessing current petsc should
> work on sx9.
> If you encounter problems building on sx9 - then send us the error
> logs at petsc-maint at mcs.anl.gov
> Satish
> On Tue, 11 Aug 2009, Joel Guerrero wrote:
>> Hi,
>> I wonder if somebody have experience in porting petsc to a nec sx9
>> computer?
>> Cheers,
>> joel
