cannot find -lustdio with matlab on
Weiwei Wang
wangww2011 at gmail.com
Mon Aug 10 22:10:50 CDT 2009
Thanks a lot, it's ok using the code
PetscViewer viewer;
PetscViewerASCIIOpen(PETSC_COMM_WORLD, "K1.m", &viewer);
PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_MATLAB);
MatView(data->K1, viewer);
but failed with the code
MatView(data->K1, PETSC_VIEWER_MATLAB_WORLD);
as the document say "Note: Currently can only save PETSc vectors to .mat
files, not matrices"
weiwei wang
Hong Zhang wrote:
> weiwei,
> The easist way is run your petsc code with the option
> '-mat_view_matlab', and dump it into a file.
> Then use Matlab to load it for whatever you want to investigate.
> See petsc user manual on "Using Matlab with PETSc".
> Hong
> On Mon, 10 Aug 2009, Weiwei Wang wrote:
>> Dear All,
>> I want to check the determinant of some sparse matrix in petsc
>> but I didn't know how to do it using petsc directly so I try to save
>> the sparse matrix in Matlab format, then calculate the determinant in
>> Matlab, so I reinstalled petsc with the opinion
>> "--with-matlab-dir=...", but the following error appeared:
>> /usr/bin/ld: cannot find -lustdio
>> collect2: ld returned 1 exit status
>> make[2]: [shared_linux] Error 1 (ignored)
>> I don't know where I can find the lib "ustdio" or other ways to
>> calculate the determinant, the system of my box is debian 5, so any
>> suggestion is appreciated.
>> Thanks,
>> weiwei wang
