cannot find -lustdio with matlab on
Hong Zhang
hzhang at mcs.anl.gov
Mon Aug 10 09:10:47 CDT 2009
weiwei,
The easist way is run your petsc code with the option
'-mat_view_matlab', and dump it into a file.
Then use Matlab to load it for whatever you want to investigate.
See petsc user manual on "Using Matlab with PETSc".
Hong
On Mon, 10 Aug 2009, Weiwei Wang wrote:
> Dear All,
> I want to check the determinant of some sparse matrix in petsc but I
> didn't know how to do it using petsc directly so I try to save the sparse
> matrix in Matlab format, then calculate the determinant in Matlab, so I
> reinstalled petsc with the opinion "--with-matlab-dir=...", but the following
> error appeared:
> /usr/bin/ld: cannot find -lustdio
> collect2: ld returned 1 exit status
> make[2]: [shared_linux] Error 1 (ignored)
> I don't know where I can find the lib "ustdio" or other ways to calculate the
> determinant, the system of my box is debian 5, so any suggestion is
> appreciated.
> Thanks,
> weiwei wang
