How to generate a parallel matrix with a sequential dense matrix?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Sep 22 18:00:02 CDT 2008
  Likely it would be better; it should not be worse.
   Barry
On Sep 22, 2008, at 4:44 PM, Aron Ahmadia wrote:
> Wouldn't it be better in this case to use an MPIScatterV?
> ~A
> On Mon, Sep 22, 2008 at 4:03 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>  I would only expect good performance if you used MPI calls to send
> the blocks of rows of the matrix to the process
> they belong to and use MatGetArray() to pass into the MPI_Recv to
> receive the data into.
>  Barry
> On Sep 22, 2008, at 1:34 PM, Yujie wrote:
> Thank you for your reply, Matt. I have checked the tutorials. They
> just use specified values and MatSetValues() to make a parallel
> matrix. Now, the matrix I use is in a single node of the cluster. I
> have 'M' nodes in this cluster. I need to copy the sequential matrix
> to other 'M-1' nodes and then use MatSetValues() or I just use
> MatSetvalues() in the node where the matrix is? The latter should
> work, right? thanks.
> Yujie
> On Mon, Sep 22, 2008 at 11:09 AM, Matthew Knepley
> <knepley at gmail.com> wrote:
> The right way to do this is to input the matrix using MatSetValues()
> in a distribute fashion. You can consult any of the tutorials, for
> instance
> KSP ex2 for an example of this.
> Matt
> On Mon, Sep 22, 2008 at 12:57 PM, Yujie <recrusader at gmail.com> wrote:
> > Hi, Petsc developer
> > Now, I have a sequential dense matrix. How to get a parallel
> matrix based on
> > it? thanks a lot.
> > Regards,
> > Yujie
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
