How to generate a parallel matrix with a sequential dense matrix?
Aron Ahmadia
aja2111 at columbia.edu
Mon Sep 22 16:44:41 CDT 2008
Wouldn't it be better in this case to use an MPIScatterV?
~A
On Mon, Sep 22, 2008 at 4:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I would only expect good performance if you used MPI calls to send the
> blocks of rows of the matrix to the process
> they belong to and use MatGetArray() to pass into the MPI_Recv to receive
> the data into.
> Barry
> On Sep 22, 2008, at 1:34 PM, Yujie wrote:
> Thank you for your reply, Matt. I have checked the tutorials. They just
>> use specified values and MatSetValues() to make a parallel matrix. Now, the
>> matrix I use is in a single node of the cluster. I have 'M' nodes in this
>> cluster. I need to copy the sequential matrix to other 'M-1' nodes and then
>> use MatSetValues() or I just use MatSetvalues() in the node where the matrix
>> is? The latter should work, right? thanks.
>> Yujie
>> On Mon, Sep 22, 2008 at 11:09 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> The right way to do this is to input the matrix using MatSetValues()
>> in a distribute fashion. You can consult any of the tutorials, for
>> instance
>> KSP ex2 for an example of this.
>> Matt
>> On Mon, Sep 22, 2008 at 12:57 PM, Yujie <recrusader at gmail.com> wrote:
>> > Hi, Petsc developer
>> > Now, I have a sequential dense matrix. How to get a parallel matrix
>> based on
>> > it? thanks a lot.
>> > Regards,
>> > Yujie
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080922/be7afabe/attachment.htm>
