Petsc and Slepc with multiple process groups
    Hong Zhang
    hzhang at mcs.anl.gov
    Thu Sep 18 09:19:04 CDT 2008
Yujie,
See the data structure "PetscSubcomm"
in ~petsc/include/petscsys.h
An example of its implementation is PCREDUNDANT
(see src/ksp/pc/impls/redundant/redundant.c),
for which, we first split the parent communicator with N processors
into n subcommunicator for parallel LU preconditioner,
then scatter the solution from the subcommunicator back to
the parent communicator.
Note, the scatter used there is unique for our particular
application. You likely need to implement your own scattering
according to your need.
Hong
On Thu, 18 Sep 2008, Lisandro Dalcin wrote:
> On Wed, Sep 17, 2008 at 9:22 PM, Yujie <recrusader at gmail.com> wrote:
>> Thank you very much, Lisandro. You are right. It look like a little
>> difficult to "transfer" data from one node to "N" nodes or from N nodes to M
>> nodes. My method is to first send all the data in a node and to redistribute
>> it in "N" or "M" nodes. do you have any idea about it? is it time-consuming?
>> In Petsc, how to support such type of operations? thanks a lot.
> Mmm.. I believe there is not way to do that with PETSc. You just have
> to make MPI calls. Perhaps if you can give me a bit more of details
> about your communication patters, then I can give you a good
> suggestion.
>> Regards,
>> Yujie
>> On Wed, Sep 17, 2008 at 5:05 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>>> A long as you create your SLEPc objects with the appropriate
>>> communicator (ie. the one obtained with MPI_Comm_split), then all
>>> should just work. Of course, you will have to make appropriate MPI
>>> calls to 'transfer' data from your N group to the many M groups, and
>>> the other way to collect results.
>>> On Wed, Sep 17, 2008 at 8:25 PM, Yujie <recrusader at gmail.com> wrote:
>>>> You are right :). I am thinking the whole framwork for my codes. thank
>>>> you,
>>>> Lisandro. In Step 3, there are different M slepc-based process groups,
>>>> which
>>>> should mean M communication domain for Petsc and Slepc (I have created a
>>>> communication domain for them) is it ok? thanks again.
>>>> Regards,
>>>> Yujie
>>>> On Wed, Sep 17, 2008 at 4:08 PM, Lisandro Dalcin <dalcinl at gmail.com>
>>>> wrote:
>>>>> I bet you have not even tried to actually implent and run this :-).
>>>>> This should work.  If not, I would consider that a bug. Let us know of
>>>>> any problem you have.
>>>>> On Wed, Sep 17, 2008 at 7:59 PM, Yujie <recrusader at gmail.com> wrote:
>>>>>> Hi, Petsc Developer:
>>>>>> Currently, I am using Slepc for my application. It is based on Petsc.
>>>>>> Assuming I have a cluster with N nodes.
>>>>>> My codes are like
>>>>>> main()
>>>>>> step 1: Initialize Petsc and Slepc;
>>>>>> step 2: Use Petsc; (use all N nodes in one process group)
>>>>>> step 3: Use Slepc; (N nodes is divided into M process groups. these
>>>>>> groups
>>>>>> are indepedent. However, they need to communicate with each other)
>>>>>> step 4: Use Petsc; (use all N nodes in one process group)
>>>>>> My method is:
>>>>>> when using Slepc, MPI_Comm_split() is used to divide N nodes into M
>>>>>> process
>>>>>> groups which means to generate M communication domains. Then,
>>>>>> MPI_Intercomm_create() creates inter-group communication domain to
>>>>>> process
>>>>>> the communication between different M process groups.
>>>>>> I don't know whether this method is ok regarding Petsc and Slepc.
>>>>>> Because
>>>>>> Slepc is developed based on Petsc. In Step 1, Petsc and Slepc is
>>>>>> initialized
>>>>>> with all N nodes in a communication domain. Petsc in Step 2 uses this
>>>>>> communication domain. However, in Step 3, I need to divide all N
>>>>>> nodes
>>>>>> and
>>>>>> generate M communication domains. I don't know how Petsc and Slepc
>>>>>> can
>>>>>> process this change? If the method doesn't work, could you give me
>>>>>> some
>>>>>> advice? thanks a lot.
>>>>>> Regards,
>>>>>> Yujie
>>>>> Lisandro Dalcín
>>>>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>>>>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>> Tel/Fax: +54-(0)342-451.1594
>>> Lisandro Dalcín
> Lisandro Dalcín
