Petsc and Slepc with multiple process groups
Lisandro Dalcin
dalcinl at gmail.com
Thu Sep 18 08:44:41 CDT 2008
On Wed, Sep 17, 2008 at 9:22 PM, Yujie <recrusader at gmail.com> wrote:
> Thank you very much, Lisandro. You are right. It look like a little
> difficult to "transfer" data from one node to "N" nodes or from N nodes to M
> nodes. My method is to first send all the data in a node and to redistribute
> it in "N" or "M" nodes. do you have any idea about it? is it time-consuming?
> In Petsc, how to support such type of operations? thanks a lot.
Mmm.. I believe there is not way to do that with PETSc. You just have
to make MPI calls. Perhaps if you can give me a bit more of details
about your communication patters, then I can give you a good
suggestion.
> Regards,
> Yujie
> On Wed, Sep 17, 2008 at 5:05 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> A long as you create your SLEPc objects with the appropriate
>> communicator (ie. the one obtained with MPI_Comm_split), then all
>> should just work. Of course, you will have to make appropriate MPI
>> calls to 'transfer' data from your N group to the many M groups, and
>> the other way to collect results.
>> On Wed, Sep 17, 2008 at 8:25 PM, Yujie <recrusader at gmail.com> wrote:
>> > You are right :). I am thinking the whole framwork for my codes. thank
>> > you,
>> > Lisandro. In Step 3, there are different M slepc-based process groups,
>> > which
>> > should mean M communication domain for Petsc and Slepc (I have created a
>> > communication domain for them) is it ok? thanks again.
>> > Regards,
>> > Yujie
>> > On Wed, Sep 17, 2008 at 4:08 PM, Lisandro Dalcin <dalcinl at gmail.com>
>> > wrote:
>> >> I bet you have not even tried to actually implent and run this :-).
>> >> This should work. If not, I would consider that a bug. Let us know of
>> >> any problem you have.
>> >> On Wed, Sep 17, 2008 at 7:59 PM, Yujie <recrusader at gmail.com> wrote:
>> >> > Hi, Petsc Developer:
>> >> > Currently, I am using Slepc for my application. It is based on Petsc.
>> >> > Assuming I have a cluster with N nodes.
>> >> > My codes are like
>> >> > main()
>> >> > step 1: Initialize Petsc and Slepc;
>> >> > step 2: Use Petsc; (use all N nodes in one process group)
>> >> > step 3: Use Slepc; (N nodes is divided into M process groups. these
>> >> > groups
>> >> > are indepedent. However, they need to communicate with each other)
>> >> > step 4: Use Petsc; (use all N nodes in one process group)
>> >> > My method is:
>> >> > when using Slepc, MPI_Comm_split() is used to divide N nodes into M
>> >> > process
>> >> > groups which means to generate M communication domains. Then,
>> >> > MPI_Intercomm_create() creates inter-group communication domain to
>> >> > process
>> >> > the communication between different M process groups.
>> >> > I don't know whether this method is ok regarding Petsc and Slepc.
>> >> > Because
>> >> > Slepc is developed based on Petsc. In Step 1, Petsc and Slepc is
>> >> > initialized
>> >> > with all N nodes in a communication domain. Petsc in Step 2 uses this
>> >> > communication domain. However, in Step 3, I need to divide all N
>> >> > nodes
>> >> > and
>> >> > generate M communication domains. I don't know how Petsc and Slepc
>> >> > can
>> >> > process this change? If the method doesn't work, could you give me
>> >> > some
>> >> > advice? thanks a lot.
>> >> > Regards,
>> >> > Yujie
>> >> Lisandro Dalcín
>> >> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> >> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> >> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> >> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> >> Tel/Fax: +54-(0)342-451.1594
>> Lisandro Dalcín
Lisandro Dalcín
