setting complex numbers
    Matthew Knepley
    knepley at gmail.com
    Mon Sep  8 09:56:14 CDT 2008
You have not called PetscInitialize() so PETSC_i has not been defined.
   Matt
On Mon, Sep 8, 2008 at 9:44 AM, zhifeng sheng <z.sheng at ewi.tudelft.nl> wrote:
> Dear all
> I am now working with the complex version of Petsc but have some serious
> problems...
> It turned out that I could not set the imaginary part of a PetscScalar.
>  Check the following code:
> int main(int argc, char *argv[])
>   #if !defined(PETSC_USE_COMPLEX)
>       SETERRQ(1,"This example requires complex numbers");
>   #endif
>     PetscScalar ee = 3.0*PETSC_i;
>     PetscScalar x = 4.0 + ee;
>     std::cout<<PetscRealPart(x)<<" "<<PetscImaginaryPart(x)<<std::endl;
> after compiling and run, it produces
> 4 0
> which means that the imaginary part is set to be zero....
> does anyone have this problem before, or could you please tell me what I did
> wrong in this piece of code.
> Thanks a lot
> Best regards
> Zhifeng Sheng
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
