setting complex numbers
zhifeng sheng
z.sheng at ewi.tudelft.nl
Mon Sep 8 09:44:31 CDT 2008
Dear all
I am now working with the complex version of Petsc but have some serious
problems...
It turned out that I could not set the imaginary part of a PetscScalar.
Check the following code:
int main(int argc, char *argv[])
#if !defined(PETSC_USE_COMPLEX)
SETERRQ(1,"This example requires complex numbers");
#endif
PetscScalar ee = 3.0*PETSC_i;
PetscScalar x = 4.0 + ee;
std::cout<<PetscRealPart(x)<<" "<<PetscImaginaryPart(x)<<std::endl;
after compiling and run, it produces
4 0
which means that the imaginary part is set to be zero....
does anyone have this problem before, or could you please tell me what I
did wrong in this piece of code.
Thanks a lot
Best regards
Zhifeng Sheng
