make test on sgi
Thu Nov 13 21:17:36 CST 2008
   This message is harmless.
    Barry
On Nov 13, 2008, at 8:51 PM, Manav Bhatia wrote:
> Hi,
>  I have built a static petsc library on sgi running suse 10.
>  When I run make test, I get the following message, which I am not
> able to decide if it is harmless or not. Please let me know if
> anyone has seen this in the past.
> Regards,
> Manav
> manav at ericjohnson:petsc-2.3.3-p13> make test
> Running test examples to verify correct installation
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with
> 1 MPI process
> ex19(10331): unaligned access to 0x6000000000f7c0e4,
> ip=0x40000000006a5b71
> ex19(10330): unaligned access to 0x6000000000f9bcb4,
> ex19(10330): unaligned access to 0x6000000000f9bcac,
> ex19(10331): unaligned access to 0x6000000000f7c0dc,
> ip=0x40000000002d9750
> ex19(10330): unaligned access to 0x6000000000f9bc6c,
> ip=0x200000000051b250
> 2 MPI processes
> Graphics example src/snes/examples/tutorials/ex19 run successfully
> with 1 MPI process
> Completed test examples
> my configuration options are:
> ./config/configure.py --with-clanguage=C++  --with-c-support --with-
> fc=0 --with-shared=0 --with-debugging=no --with-mpi=true --with-
> mpirun=mpirun --with-mpi-include=/usr/include --with-mpi-lib=[/usr/
> lib/libmpi++.so,/usr/lib/libmpi.so] --with-parmetis=true --with-
> parmetis-dir=/l/manav/codes/ParMetis-3.1 --with-blas-lib=[/usr/lib/
> libblas.so,-lgfortran] --with-lapack-lib=[/usr/lib/liblapack.so,-
> lgfortran] --with-x
