make test on sgi
Manav Bhatia bhatiamanav at gmail.com
Thu Nov 13 20:51:41 CST 2008
   I have built a static petsc library on sgi running suse 10.
   When I run make test, I get the following message, which I am not
able to decide if it is harmless or not. Please let me know if anyone
has seen this in the past.
Manav
manav at ericjohnson:petsc-2.3.3-p13> make test
Running test examples to verify correct installation
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
ex19(10331): unaligned access to 0x6000000000f7c0e4,
ip=0x40000000006a5b71
ex19(10330): unaligned access to 0x6000000000f9bcb4,
ex19(10330): unaligned access to 0x6000000000f9bcac,
ex19(10331): unaligned access to 0x6000000000f7c0dc,
ip=0x40000000002d9750
ex19(10330): unaligned access to 0x6000000000f9bc6c,
ip=0x200000000051b250
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
MPI processes
Graphics example src/snes/examples/tutorials/ex19 run successfully
with 1 MPI process
Completed test examples
my configuration options are:
./config/configure.py --with-clanguage=C++  --with-c-support --with-
fc=0 --with-shared=0 --with-debugging=no --with-mpi=true --with-
mpirun=mpirun --with-mpi-include=/usr/include --with-mpi-lib=[/usr/lib/
libmpi++.so,/usr/lib/libmpi.so] --with-parmetis=true --with-parmetis-
dir=/l/manav/codes/ParMetis-3.1 --with-blas-lib=[/usr/lib/libblas.so,-
lgfortran] --with-lapack-lib=[/usr/lib/liblapack.so,-lgfortran] --with-x
