Slow MatSetValues
Lisandro Dalcin dalcinl at gmail.com
Thu May 29 16:44:56 CDT 2008
I will not buy at first that things can be done better than looping
over elements filling a std::vector< std::set<int> >, next filling a
vector with each row size, next preallocating the AIJ matrix, and
finally another loop filling matrix rows with zeros, ones, or garbage.
All this are about 10-20 lines of code using simple C++ STL containers
and a few calls to PETSc.
If anyone has a better way, and can demostrate it with actual timing
numbers and some self contained example code, the perhaps I can take
the effort of adding something like this to PETSc. But I doubt that
this effort is going to pay something ;-).
On 5/29/08, Billy Araújo <billy at dem.uminho.pt> wrote:
> Hi,
>  I just want to share my experience with FE assembly.
>  I think the problem of preallocation in finite element matrices is that you
> don't know how many elements are connected to a given node, there can be 5,
> 20 elements or more. You can build a structure with the number of nodes
> connected to a node and then preallocate the matrix but this is not very
> efficient.
>  I know UMFPACK has a method of forming triplets with the matrix information
> and then it has routines to add duplicate entries and compress the data in a
> compressed matrix format. Although I have never used UMFPACK with PETSC. I
> also don't know if there are similiar functions in PETSC optimized for FE
> matrix assembly.
>  Regards,
>  Billy.
>  -----Mensagem original-----
>  De: owner-petsc-users at mcs.anl.gov em nome de Barry Smith
>  Enviada: qua 28-05-2008 16:03
>  Para: petsc-users at mcs.anl.gov
>  Assunto: Re: Slow MatSetValues
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manual.pdf#sec_matsparse
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatCreateMPIAIJ.html
>  Also, slightl less important,  collapse the 4 MatSetValues() below
>  into a single call that does the little two by two block
>      Barry
>  On May 28, 2008, at 9:07 AM, Lars Rindorf wrote:
>  > Hi everybody
>  > I have a problem with MatSetValues, since the building of my matrix
>  > takes much longer (35 s) than its solution (0.2 s). When the number
>  > of degrees of freedom is increased, then the problem worsens. The
>  > rate of which the elements of the (sparse) matrix is set also seems
>  > to decrease with the number of elements already set. That is, it
>  > becomes slower near the end.
>  > The structure of my program is something like:
>  > for element in finite elements
>  >     for dof in element
>  >         for equations in FEM formulation
>  >             ierr =
> MatSetValues(M->M,1,&i,1,&j,&tmp,ADD_Values);
>  >             ierr =
> MatSetValues(M->M,1,&k,1,&l,&tmp,ADD_Values);
>  >             ierr =
> MatSetValues(M->M,1,&i,1,&l,&tmp,ADD_Values);
>  >             ierr =
> MatSetValues(M->M,1,&k,1,&j,&tmp,ADD_Values);
>  > where i,j,k,l are appropriate integers and tmp is a double value to
>  > be added.
>  > The code has fine worked with previous version of petsc (not
>  > compiled by me). The version of petsc that I use is slightly newer
>  > (I think), 2.3.3 vs ~2.3.
>  > Is it something of an dynamic allocation problem? I have tried using
>  > MatSetValuesBlock, but this is only slightly faster. If I monitor
>  > the program's CPU and memory consumption then the CPU is 100 % used
>  > and the memory consumption is only 20-30 mb.
>  > My computer is a red hat linux with a xeon quad core processor. I
>  > use Intel's MKL blas and lapack.
>  > What should I do to speed up the petsc?
>  > Kind regards
>  > Lars
>  > _____________________________
>  > Lars Rindorf
>  > M.Sc., Ph.D.
>  > http://www.dti.dk
>  > Danish Technological Institute
>  > Gregersensvej
>  > 2630 Taastrup
>  > Denmark
>  > Phone +45 72 20 20 00
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
